![]() | Home > Technical (L322) > Power cable to speed camera warning device |
Mudplugger Member Since: 20 Feb 2009 Location: err... near Inglewhite, Lancs. Posts: 95 ![]() ![]() ![]() |
I need to get a power cable connected to the speed camera warning device I have mounted on the plastic binnacle in the windscreen area above the RHS air vent (and wood trim).
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
There should be a Perm Live in the lower Kick Panel (The Plastic bit by your right foot) |
Thanks Ken,
pull the vent out first then unscrew the rest of the trim |
Any clips inside the vent as usual? Range Rover Vogue SE SDV8 - L405 (now sadly sold)
Yep a good pull will work fine |
Thanks Ken. Range Rover Vogue SE SDV8 - L405 (now sadly sold)
look in RRUK's post re TV on the move you will see the vent out then the screws |
All done!
mintleaf Member Since: 28 Mar 2009 Location: London Posts: 19 ![]() ![]() ![]() |
All sorted now...cheers |
alexbartman Member Since: 08 Dec 2009 Location: UK Posts: 43 ![]() ![]() |
I'm trying to do exactly the same fit with my Pogo - can you help me out with kick panel removal and then picking the right wires for live and earth.....any advice gratefully received!
tucker_j Member Since: 01 May 2010 Location: Kent Posts: 14 ![]() |
Hi All,
Sorry I'd not picked up on these posts earlier.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3758 ![]() ![]() |
I mounted mine in the same location - on the plastic binnacle in the windscreen area above the RHS air vent and wood trim. But did a really simple installation.
