Home > Technical (L322) > Pre heater issue
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
Pre heater issue
Morning
MY2011 4.4 TDV8.
I have just brought this car and have replaced the battery in my pre heater remote, the light flashed red once and now no matter how many times i press the button it is not working. Any ideas ?
I am going to set the pre heat to come on at 08:00 tomorrow from the car to see if that works, as I dont know if the pre heater is working
Mick 2011 Range Rover Vogue SE
Post #424713 25th Jan 2017 11:59am
mzplcg
Sounds like the FBH might be locked out. If it tries to start and fails 3 times it has to be reset. There is a fuse you can pull or a battery disconnect will do the same.
Post #424716 25th Jan 2017 12:12pm
Busa1400
Thankyou - any idea on the fuse to pull as I don't fancy disconnecting the battery 2011 Range Rover Vogue SE
Post #424724 25th Jan 2017 12:47pm
peejay
England 2009 Range Rover Vogue SE TDV8 Santorini Black
If it's the original remote with the extended aerial then it should be fuse 59 in the fuse board behind the front lower glove box, pull it out for about 10 seconds then push in and press the off button on the remote for a few seconds at the same time, that's how others on here have done it, hope this helps
Post #424770 25th Jan 2017 4:42pm
Busa1400
Thanks 2011 Range Rover Vogue SE
Post #424779 25th Jan 2017 6:06pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
To rule out battery problems..give it a full charge. You can even leave the battery charger connected.
Get in the car, and wait a few minutes for the car to go to sleep.
Then press remote fob....
Post #424783 25th Jan 2017 7:11pm
Busa1400
Sorry what I meant was the red light came on, on the key fob once but that was it, it has not illuminated since 2011 Range Rover Vogue SE
Post #424785 25th Jan 2017 7:28pm
