Home > Technical (L322) > Pre heater issue |
Sounds like the FBH might be locked out. If it tries to start and fails 3 times it has to be reset. There is a fuse you can pull or a battery disconnect will do the same. |
25th Jan 2017 12:12pm |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 |
Thankyou - any idea on the fuse to pull as I don't fancy disconnecting the battery 2011 Range Rover Vogue SE |
25th Jan 2017 12:47pm |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 |
If it's the original remote with the extended aerial then it should be fuse 59 in the fuse board behind the front lower glove box, pull it out for about 10 seconds then push in and press the off button on the remote for a few seconds at the same time, that's how others on here have done it, hope this helps |
25th Jan 2017 4:42pm |
Thanks 2011 Range Rover Vogue SE |
25th Jan 2017 6:06pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 797 |
To rule out battery problems..give it a full charge. You can even leave the battery charger connected.
25th Jan 2017 7:11pm |
Sorry what I meant was the red light came on, on the key fob once but that was it, it has not illuminated since 2011 Range Rover Vogue SE |
25th Jan 2017 7:28pm |
