Home > Technical (L322) > A few Questions regarding my L322 Td6
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Mines a lowley HSE and has a FBH - not sure if it was an 'extra' but it is there !
Cheers
Simon
Post #424630 24th Jan 2017 7:23pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
All the talk of FBH's and I never even bothered to check, I just assumed as a HSE it wouldn't have one, which knowing my luck it probably won't.
Not that I'd probably ever use it, if it's that cold I usually just leave it running to thaw out before I set off, and before anyone says about not safe/illegal etc., short of lifting it with a Chinook it isn't going anywhere.
But I must have a look, thanks.
Post #424637 24th Jan 2017 7:58pm
Strangerover
Australia 2002 Range Rover HSE Td6 Giverny Green
Mine was down on power, turned out that the vacuum line to the turbo was perished, so the variable vanes weren't being actuated. Replaced lines, wow what a difference. Think it had been leaking for quite some time. I'd suggest you had a vacuum leak issue- perhaps not in the turbo line but elsewhere, dropping the overall vacuum.
Post #428065 17th Feb 2017 8:54am
