Home > Maintenance & Mods (L322) > wiring up 2010 rear lights
Page 1 of 3 123>
daveo
hi all, there are a few people like my self on this forum that are finding the 2010 rear lights more attractive.
but tere lots of questions about whats the best way to wire them up,what resitsters to use, what wires and where to cut into the loom, fog light issues,a member posted "just need a relay and a resister"and even that you have to cut the body work Shocked well lets find out what relay and where to put it, some of these resiters can get very hot so caution should be used as no one wants to watch there 2010 lights glowing as the rest of the car is on fire.
PICTURES are whats needed and lets make them good ones,
the lights are now dropping below the £300 a set
agian i would like to add led 's for the front indicator,any advice will be great to all...
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #42068 12th Dec 2010 9:07pm
will this help dave..
http://www.l322.com/
if not i think nickj has an 2010 upgrade , maybe he can help... ... - .- -.
Post #42070 12th Dec 2010 9:21pm
bozmandb9
I'll let you know how I get on with mine, since they come complete with resistors. I'm sure there's no cutting of bodywork, I was talking to a Land Rover sales guy today and he said they had upgraded some earlier cars with the later lights and they're an easy fit.
I know the front light upgrade requires bodywork modification, maybe somebody was mixed up?
Good point about the car catching fire, it's prompted me to think it's probably something which you need to inform the insurance company about? Range Rover-less at the moment - Pining!
Post #42072 12th Dec 2010 9:22pm
daveo
hi scarey, yes i know adam from l322, he helped me with my bluetooth conversion, he was one of the first to do the 2010 conversion on his car and soon found out about the fog light issue, he has also got the 2010 mirrors fitted and working as well. he has a full list of the wires for the 2006 and 2010 headlamps. V8 facelift Range Rover Autobiography 22" wheels.
Post #42079 12th Dec 2010 9:56pm
there's a surprising amount of info on that site, especially the wiring diagrams.... ... - .- -.
Post #42109 13th Dec 2010 8:28am
bozmandb9
Anybody have any ideas or knowledge about this? I've received my set of 2010 lights, and they have resistors to resolve the indicator issues. The resistors are to be mounted on the outside of the inner skin, in order to dissipate heat.
No mention is made of a resolution to any possible issues with the foglights though, the vendor says that the only problem is usually that the fog light on light will come on initially when you start up the car, but I've heard from my mechanic that when they fitted a set before the foglight remained partly on all the time.
Any feedback or advice would be welcomed! Range Rover-less at the moment - Pining!
Post #42348 14th Dec 2010 10:18pm
daveo
hi, as far as i know they are on when you switch on the side lights as the fogs share the same supply, its the lcm that controls the voltage to make them brighter when fogs are selected and with a standard lcm it puts full power to them all the time,hench the fogs always on.. V8 facelift Range Rover Autobiography 22" wheels.
Post #42350 15th Dec 2010 12:24am
bozmandb9
Does that make it an MOT failure? Anybody have any work arounds or fixes? Range Rover-less at the moment - Pining!
Post #42357 15th Dec 2010 9:18am
daveo
yes it will fail if he is a jobs worth... V8 facelift Range Rover Autobiography 22" wheels.
Post #42410 15th Dec 2010 5:15pm
T24RES
Or just doing his job............... Rolling Eyes Ian
Post #42414 15th Dec 2010 6:18pm
oodathort
Hi the fog light circuit has around 4 volts on it all the while so you need to insert a relay so that with 4 volts across the coil it will not energise however when you switch the fogs on the 4 voltts rises to 12 volts and then powers the lamp you will require a resistor across this to rid the error message
Post #42417 15th Dec 2010 6:54pm
bozmandb9
What i've been advised by the nice chaps at L322.com is to disconnect the wire to the fogs as a work around, if the guys fitting it can't find another solution I'll live with this until a better solution is found (and published!). Range Rover-less at the moment - Pining!
Post #42421 15th Dec 2010 7:18pm
oodathort
doing that will give you a fog light error all the time i have done this conversion with no problems
Post #42422 15th Dec 2010 7:22pm
daveo
hi oodathort, have you done this to your car and if so can you take a few pics and post them, what relay and resister did you use..
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #42431 15th Dec 2010 8:36pm
oodathort
sorry about the quaity but only have camera on phone and its crap Porsche Cayenne
RR Sport TD6
Porsche 911sc
AM vanquish
AM Db7
AM DB7
Lotus Esprit V8
Lotus esprit V8
Lotus esprit V8
Lotus esprit 2,2 turbo
lotus espirit 2lt turbo
lotus excel
escort 16 i
capri 2.8i
lotus sunbeem
jenson interceptor
land rover series 1
MGBGT
MG Roadster
Post #42455 16th Dec 2010 6:54am
Page 1 of 3 123>
