Home > Off Topic > iPhone battery replacement
Has anyone done this and can reccomend a source where the batteries last a good while, or 5-6months as most people I've found that DIY with eBay and Amazon batteries only last a few weeks to a couple of months Sad
My iPhone 6 is on its second battery but being out of warranty Apple want £149 to do the job Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #424117 21st Jan 2017 4:26pm
A pig of a DIY job - I took my sons iphone 5 to a local second hand phone shop who did it while I waited
Post #424121 21st Jan 2017 4:35pm
I'm fine to do it but worry about such shops as they may not be there in a few months time and also not sure how good the batteries are they use Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #424123 21st Jan 2017 4:39pm
mzplcg
Who makes the genuine Apple one? It won't be Apple for sure. Perhaps google can provide some info, but it's likely to be Quallion or Samsung at a guess.
Post #424127 21st Jan 2017 5:31pm
plenty of genuine apple batteries on Ebay for about £15. I have done a couple in both iPhone 5s and 6. Its an easy job and takes about 5 mins, and some even come with all the tools needed. get some sticky strips too off eBay.
the 6 is particularly easy.
undo the 2 screws either side of the charging connector
use a sucker and a spudger and gently lift the screen from the bottom
lift the screen back and you will see the battery.
carefully support the screen. you then need to pull on the sticky tabs which glue the battery in. these pull down towards the bottom of the battery.
then undo the connector plate which holds the battery connector in (about 2/3 of the way down the motherboard)
you can then lift out the battery.
reverse to fit new one.
it will take a little bit of charge going in to get it to fire up, so leave it on charge for an hour or 2 before you try and switch it on.
there is a great app/website for mending stuff called Ifixit. you download it it then has instructions on how to fix most things including battery swaps etc, or use the web:
https://www.ifixit.com/Guide/iPhone+6+Battery+Replacement/29363
to be honest once you have done it you won't mind doing it again. The batteries are so cheap and quick to swap that it doesn't matter if it lasts 6 months or 12 months. There is nothing that can't be fixed with a hammer😜😜
Post #424134 21st Jan 2017 6:28pm
Can you reccomend a link at all NMj to one on eBay or the like? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #424137 21st Jan 2017 6:48pm
last one i got was a random click on eBay for an iPhone 5. I got my 6 done at a phone shop, they charged me £40...... after a day the battery started rattling around so I had it apart and they hadnt put and new sticky, on it Rolling Eyes hence how i know how to strip it down. Knowing that part i then got bored of the scratched silver case and swapped the whole internals into a matt black case......that is a PITA to do, but at least it means i know how to strip one into its components!!
Personaly i would take any of the purported genuine ones under £15 quids with UK shipping and tools. If its crap then try a different vendor next time. Just type in "genuine replacement battery iphone6"
this chap for example says its original has 17000 feedback at 99.8%
http://www.ebay.co.uk/itm/100-GENUINE-ORIG...Sw44BYYtJB
gotta be worth a punt for £7.50....... There is nothing that can't be fixed with a hammer😜😜
Post #424141 21st Jan 2017 6:58pm
Cheers fella Smile
Hit BIN straight away so let's see what it holds as I'll do it before bed and can leave it to charge overnight Smile
Just want it sorted before I go away next week as he temps will be hard enough on any battery anyway Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #424146 21st Jan 2017 7:58pm
Good luck take your time and follow the iFixit and don't lose the screws!!
Hope that battery is decent, for that money it's got to be worth a go! There is nothing that can't be fixed with a hammer😜😜
Post #424151 21st Jan 2017 8:09pm
Fingers crossed and thank you Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #424159 21st Jan 2017 8:49pm
