Home > Technical (L322) > no drive after flat battery
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
please can anyone help i was trying to change the nearside front airbag fri 13 couldnt get a bolt undone ,had a heart attack ,went in hosp 2 days later battery was flat as i had left things on door open ,charged the battery overnight last night started straight up this morning put it in drive nothing put it in reverse nothing changed from high to low nothing,so now no drive has anybody had this prob and know what it is,thanks.
Post #423474 18th Jan 2017 11:12am
Glad to hear you're OK
I've not heard of that problem before - so it lets you change into drive, but then doesn't move & doesn't rev when you press the accelerator - is that right ?
Post #423477 18th Jan 2017 11:44am
cowman
i had the nearside front stripped nealy the bottom leg bolt was seized so then i left it came out of hospital yesterday battery was flat charged it overnight ,started first turn this morning ,put in drive nothing ,put in reverse nothing even with slight revs i then noticed h/l flashing so put in n pressed h/l switch light gone out but still no drive ,will a hard reset help this.
Post #423480 18th Jan 2017 11:56am
Hard reset certainly won't do any harm - so has to be worth a try Thumbs Up
Post #423490 18th Jan 2017 12:45pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I had this before and it turned out to be fuse 37 had been left in and it put the transfer box into neutral.
If there is a fuse in 37 - remove it!
I hope this fixes it.
regards
John
Post #423492 18th Jan 2017 1:03pm
cowman
no just checked fuse 37 and no fuse in there it is frustrating as i cant do anything i have got to rest ,
Post #423499 18th Jan 2017 1:54pm
Are you with the AA / RAC ?
If so, get them out to take a look
May need a fault reader to see what the car is upset about.
Post #423503 18th Jan 2017 2:48pm
