Home > Maintenance & Mods (L322) > [SOLVED] TD6 Coolant Leak Engine Side - can't find it?
mariner30
United Kingdom 2003 Range Rover SE Td6 Rimini Red
Still leaking but now identified as joint between thermostat and bottom hose. Looks like I need a new O seal. Anyone know the size so I can try and get one tomorrow (Saturday)?
Post #422645 13th Jan 2017 10:55pm
mariner30
Searched high and low for a new O seal for the bottom hose to thermostat housing. LR only sell the whole rigid connector, you won't be surprised to hear. Eventually got one from my local village garage which was "rounder" than the old one. In the process of fitting it I noticed that the blanking cap for the EGR removal kit was split (the one leading off the bottom hose, caused by the tight jubilee clip, the one on the left in the picture). Cut it back (it's very soft "rubber") and refitted - leak fixed. Re-fitted all the bits I had taken off (including the vacuum pump on the front of the engine which I had to remove to get to the lower screw holding the turbo air supply tube). Topped up with fresh water and run the engine. And for the first time in months the engine temp reached 12 o'clock! And no leaks. I am now wondering whether to put the viscous fan back on. Perhaps I will put it on for my next trip away and then remove it for local running to test.
Anyway lesson learnt - thoroughly check all hoses, particularly the last fitted!
Tomorrow, drain the water and refill with coolant, and refit fan and shroud, bottom cover and go for a test drive!
Post #422953 15th Jan 2017 7:43pm
Well done!
You really do not need the fan, or the shroud for that matter in these climes. Does make the air con fans kick in a bit more regularly when stationary though. However, makes for easy access when the next thing goes wrong! .
Post #422974 15th Jan 2017 10:41pm
mariner30
Thanks Joe90. It's all back together now and seems OK. I have fitted the fan just for the time being but will remove it if everything is OK after my trip away. I did notice the A/C fans cutting in regularly as the car was warming up on the driveway. What happens in the summer - do they run constantly in slow traffic? Are they as tough as the viscous fan since they are going to be running much more?
Post #423110 16th Jan 2017 6:21pm
Difficult to tell what is going on in the summer as the temp gauge is "fixed" so to speak, but mine sits solid at 12 o'clock, even on a very hot day in traffic, you can't hear the fans as you are sitting inside an air con luxury box Very Happy .
Post #423159 16th Jan 2017 9:23pm
mariner30
Thanks again Joe90. You are quite right that A/C luxury can mask anything - it's only the pedestrians who look surprised!
Post #423189 16th Jan 2017 11:57pm
