Home > Maintenance & Mods (L322) > Rear tail light bulb failure message
RR-EVO
France 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hello,
I have the rear tail light bulb failure message. Car is 4.2 SC 2006.
Bulbs are all fine. I removed the lights and cleaned, sanded and electrical greased the bulb connectors and electrical sockets
Is it a known problem.
Should i purchase new bulb holders?
Thanks
Florent
Post #423021 16th Jan 2017 11:32am
has the error message now gone since you have cleaned the contacts..
Post #423022 16th Jan 2017 11:36am
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Mines the same. It always bongs and says "check brake light" when starting or turning off. It did it before and after I updated the tail lights, so it's presumably, like yours, a fault in the continuity PWM circuit NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #423024 16th Jan 2017 11:44am
RR-EVO
No...
I suspect either a problem with the wiring of the vehicle or with the ECU
Post #423028 16th Jan 2017 11:56am
any replacement led bulbs fitted per chance?
Post #423029 16th Jan 2017 12:00pm
RR-EVO
No vehicle is stock. No message during 6 months of ownership.
Battery is new
Post #423031 16th Jan 2017 12:10pm
strange...it might be an intermittent bulb failure or as you have suggested, a fault in the wiring ..
Post #423033 16th Jan 2017 12:13pm
