Home > Technical (L405) > Engine stats
Landroverfan1
Engine stats
Does anyone know where I can find some statistics on the two Diesel engines for the L405? Specifically I'm looking for those real world acceleration and braking figures e.g. 30-50mph, 50-70mph.
Many thanks.
Post #422831 15th Jan 2017 8:26am
For the 4.4 this is all I have - source automobile-catalog.com
Powertrain
Engine manufacturer:
Ford 4.4 TD V8
Engine type:
diesel
Fuel type:
diesel fuel
Fuel system:
common rail
Charge system:
2 turbochargers
Valves per cylinder:
4
Valves timing:
Additional features:
DOHC
Emission control:
DPF, oxi-cat, EGR
Emission standard:
Euro 5
Cylinders alignment:
V 8
Displacement:
4367 cm3 / 267.1 cui
Bore:
84 mm / 3.31 in
Stroke:
98.5 mm / 3.88 in
Compression ratio:
16.1 : 1
Horsepower net:
249.5 kW / 339 PS / 335 hp (ECE)
/ 3500
Torque net:
700 Nm / 516 ft-lb
/ 1750 - 3000
Car power to weight ratio net:
109.2 watt/kg / 49.5 watt/lb
Car weight to power ratio net:
9.2 kg/kW / 6.7 kg/PS / 15 lbs/hp
Fuel capacity:
105 liter / 27.8 U.S. gal / 23.1 imp. gal
1000rpm speed:
(km/h/mph)
I:11.2 / 7
II:16.8 / 10.4
III:25 / 15.5
IV:31.6 / 19.6
V:41 / 25.5
VI:52.7 / 32.8
VII:62.8 / 39
VIII:79 / 49.1
Top speed:
217 km/h / 135 mph
electronically governed
0-60 mph (s):
6.5
0-100 km/h (s):
6.9
Post #422837 15th Jan 2017 9:26am
Doodle
SDV8 2015 had new torque converter and increase in torque to improve in gear performance, 50-70 mph being one of the bands. If I recall, the bhp remained about the same.
If you check back on Forum, I believe this has been covered.
Post #422852 15th Jan 2017 10:26am
Doodle
Should have added Torque increased from 700N. to 740N.m (+ almost 6%)
Also the band of available torque changed to improve mid-range (eg overtaking) performance with no loss in mpg.
Post #422875 15th Jan 2017 1:32pm
http://carproductstested.com/cars/2015-ran...en-better/
Quote:
According to Land Rover, the SDV8 now has a �fuller torque curve from 1700 to 3300rpm thanks to detailed calibration changes. This improves in-gear acceleration by up to 6.5% from fifth to eighth gear, ensuring effortless overtaking ability and enhanced towing capability.�
For 2015, the 8-speed automatic transmission (ZF 8HP70) has also been re-engineered with a �revised torque converter incorporating a twin-spring damper.�
Post #422906 15th Jan 2017 5:01pm
Landroverfan1
Thanks very much for the useful links and stats.
Post #422945 15th Jan 2017 6:53pm
