![]() | Home > Technical (L322) > Flushing coolant system |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8396 ![]() ![]() ![]() |
It's all in Rave, downloadable from the WIKI... |
and I am guessing that the cylinder block drain plug on a V8 is as inaccessible as it is on the TD6 |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
@ Pete |
I just stuck a hose in the heater pipes and back flushed it through the engine, use both hoses until the water flows clean, problem with that is you end up with a lot of plain water in the system so you then have to top it up with neat antifreeze and you have diluted stuff...
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
There are two block drain plugs but the passenger side or left as you are sitting in it doesn't drain much but the right side is easyish to reach and does drain a load of coolant out the block .
Aye it's the 4.4v8 . I've had it since July and the antifreeze looked remarkably clear when I checked. Removed some old coolant then eventually had to add 2litres neat g48 to make it less likely to freeze.
