Home > In Car Electronics (L322) > Sat nav screen not working |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Yes, quite likely ! Suggest you give the males and females a good clean and a light dousing with electrical contact cleaner etc. and try again. Might also be worth fitting a water shedder over the components too. .
8th Jan 2017 11:33pm |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 |
Thanks for the reply Joe90, this is after switch cleaner had been sprayed.
9th Jan 2017 8:10am |
Ahh, difficult to see without the big red arrow
9th Jan 2017 9:21am |
Joe90 I had the same thought, no way is that standing up to straightening
9th Jan 2017 10:27am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
If you remove the satnav module from it's mounting bracket and reposition it lower down on a temporary basis and then disconnect the two plugs from the tv module you can connect the two plugs that served the tv module directly to the satnav module. Been there when I had an initial problem. I laid a folded towel in compartment to lay the satnav unit on.
9th Jan 2017 6:41pm |
When it's all plugged back in it all works even the tv, obvs no picture just static.
9th Jan 2017 9:19pm |
