Home > Technical (L322) > Air suspension inactive
tnysctt
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Screen of doom lol had a puncture in front tyre all fixed n all ok apart from the screen of doom showing air suspension inactive but all air suspnsion is fine moves up and down ok on request and all ride heights are the same am i missing something is there a reset cheers
Post #421940 9th Jan 2017 6:01pm
Weegie
First, with engine running turn steering fully from lock to lock.
If that doesn't clear it then it will be a "hard" fault which needs to be cleared with a diagnostic tool such as the Gap iiD. John
GAP iiD BT
Post #421943 9th Jan 2017 6:15pm
tnysctt
Cheers i will try that
Post #421957 9th Jan 2017 7:16pm
tnysctt
Any ideas why the air suspension would stop working via control knob after a puncture compressors working i can hear it and all heights are ok no leaks i have reset codes via secret codes in wiki cheers
Post #422246 11th Jan 2017 7:49pm
Weegie
The control knob isn't locked by any chance? Have a look at it and if there is a light showing in the centre of the knob the suspension is locked. Press the button to extinguish the light.
Hopefully that is the problem. John
GAP iiD BT
Post #422252 11th Jan 2017 8:11pm
tnysctt
Hello and yep the light on the control knob is illuminated and does not seem to turn off either by pressing once or holding for a second or 2 any ideas wud be greatly appreciated cheers
Post #422269 11th Jan 2017 9:14pm
You have a hard fault. Diagnostic tool required Thumbs Up .
Post #422283 11th Jan 2017 9:59pm
tnysctt
Cheers 😎
Post #422284 11th Jan 2017 10:00pm
