Home > Technical (L405) > Frozen air intake !
Page 1 of 3 123>
Frozen air intake !
I'm skiing at the moment and it was -13 this morning.
I tried to start the car & every time, it fired, then immediately shut down. I need to do an airport run tomorrow, so called LR assist who dispatched a local guy who was with me in under an hour.
I kind of expected it to be frozen diesel, but couldn't figure out why the car fired up each time - and I had tried probably 15 times.
The guy reckoned it was something on the air side - was able to disconnect a few pipes & start the engine - so I guess he was right.
He's now taken it away to dismantle & figure out what's frozen - all rather embarrassing as every other car seems to be perfectly fine.
I'm waiting for a call back from LR assist to see what they figure out.....
Post #421424 6th Jan 2017 1:52pm
caymanblack
Hope it gets sorted soon Alistair. Enjoy the slopes. Very Happy
Post #421429 6th Jan 2017 2:13pm
AndyS
Re: Frozen air intake !
Unnecessary quote removed
I hope they sort your problem but Land Rovers are no longer built to withstand this sort of treatment, they should be left in a heated garage unused otherwise you'll just get these sorts of issues all the time and it get's frustrating. Thumbs Up
Post #421433 6th Jan 2017 2:18pm
Big Cry
Post #421435 6th Jan 2017 2:22pm
nice place to break down though.... Thumbs Up
Post #421437 6th Jan 2017 2:36pm
I don't have a good history with ski resorts Big Cry
Turbo/intercooler hoses one year as I was climbing the mountain - so I was trying to remove the hoses in an underground garage in sub-zero tempeatures.
Another time I spung a coolant leak that required the car to be taken away in a similar fashion so that they could figure out the source - similar story, I limped into the resort & was recovered the next day.
I have another 4 weeks here though, so keen to understand what caused it. I've an airport run tomorrow - and I am flying home Mon-Thur for the next 3 weeks - so leaving the resort at 4am on Monday - so the car had better start !
Post #421438 6th Jan 2017 2:44pm
caymanblack
Theres no snow though!
Post #421449 6th Jan 2017 3:29pm
Rolling with laughter There is on the mountain (about 50% open) but not in the resort yet - but it is forecast for next week Thumbs Up
Post #421450 6th Jan 2017 3:34pm
caymanblack
Mr. Green Thumbs Up
Post #421454 6th Jan 2017 3:56pm
Doodle
Just out of interest, did you run the FBH before attempting to start. In fact would the FBH work at all given the frozen pipe possibility? Shocked
Post #421500 6th Jan 2017 7:59pm
I don't have a FBH - at least not an independently controllable one.
Even Park Heat is disabled as standard on the L405 - though apparently I can enable it with an IID tool - I wish I hadn't given mine away now when sold the L322.......
I think it's the air intake that was problematic - somewhere between the air filter & the engine - not sure where the FBH gets it's air from ?
The mechanic took the cover off the filter, but it still wouldn't go - but disconnected closer to the engine & it started but wouldn't rev.
Post #421510 6th Jan 2017 8:42pm
AndyS
Can't remember what I typed but apologies as it obviously was inappropriate, no offense meant.
Post #421521 6th Jan 2017 10:07pm
Laughing @ Andy S
It is because you keep quoting previous posts in your own (Verboten zum den Vorum!!) Thumbs Up .
Post #421531 6th Jan 2017 11:48pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Would be interesting to know the outcome as two of my reasons for having a FF is skiing (both meanings)
I had frozen diesel once, the annoying thing was it had to be reset through OBD rather than odentifying the problem had been cured and resetting itself. I also had the problem with the door mirrors this year.
I do wonder if JLR do their testing in extreme locations and think if it is good enough for that it will be fine for lesser areas. Ski resorts being just above and below freezing bring their own hazards. letters not necessarily in the right order
Post #421555 7th Jan 2017 9:32am
Baltic Blue
It might be worth bearing in mind that it is not usually the diesel that freezes but the water/moisture content within the diesel.
Keeping the filter clean helps and clearing any water from the water traps which is where the blockage usually occurs. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #421558 7th Jan 2017 9:53am
Page 1 of 3 123>
