![]() | Home > Technical (L405) > Frozen air intake ! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35602 ![]() ![]() |
i think the tank is 89 litres on the L405 so you fill up 79 litres and then 10 litres ? |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I'm sure my tank is bigger than that... maybe 90L
that makes sense... |
My 10p bet says its not freezing fuel!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Wow — an old thread
I know it's an old thread, but I learned something today related to this. Chatting to a guy who does the off road landrover experience at rockingham, he says the intake has a complex valve system designed to divert to alternative air the moment resistance from wading water is detected. In cold temperatures sometimes these valves get stuck and wont open, meaning when you start the engine your running on residual air in the pipes, you then choke the engine, it dies, then the sucked in rubber hoses de-compress after a few minutes and your able to start again, and the same happens....
http://www.fullfatrr.com/gallery/albums/us...RATION.pdf
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3808 ![]() ![]() ![]() |
Cheers Stan, you will have to give me a lesson some day |
Interestingly I think I will blank off my EGR given it's so accessible at the top. After cleaning the MAP sensor the other day I noticed the intake is full of carbon and soot |
