![]() | Home > Technical (L322) > Suspension recalibration! |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
I had a LR technician look at my car last night, kept throwing an air suspension error, I changed a height sensor and it hasn't come back, but he said my calibration was too high, and thinks that it was so high every time I go around a corner a sensor was going out of range, causing an articulation error! Does this look about right at different heights? Looks better to me than it was!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35661 ![]() ![]() |
you can check the heights yourself using this chart,
There isn't a height for the stupid 22inch wheels that are on the car, I think we did it to 20. The guy said there wasn't much in it really!
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I'm convinced mine is sitting too high.
Post a picture and we can help you out!
Those measurements Stan put up are taken from the centre of the hub so regardless of size of wheel they will work . 2008 MY Supercharged
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Yes, I put the chart together for different rims because IIRC the All Comms was taking measurements from the rim not the hub centre, if not i know there was a reason for it!
the rear is supposed to be 1cm lower than the front..
Tim - mine was about 50mm too high all around!
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Just played with mine, initially FR = 500 FL = 520 RR = 470 RR = 490 so all over the place |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Was that the measurements on the iid app or from taking them manually?? If from the iid app they will be all different ? |
@ kbald
Hi joe90 that's what I meant if he simply changed the settings using the iid tool it won't be right so he would need to e measure correctly as per the chart you produced. On the Bluetooth iid it gives you figures for the suspension on the app. |
yep, copious amount of measuring, then calibrated left to right but as the original measurements (measured from middle wheel to wheel arch) were so far out manually adjusted heights to get the car roughly square then recalibrated.
