Home > Technical (L322) > Suspension recalibration!
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I had a LR technician look at my car last night, kept throwing an air suspension error, I changed a height sensor and it hasn't come back, but he said my calibration was too high, and thinks that it was so high every time I go around a corner a sensor was going out of range, causing an articulation error! Does this look about right at different heights? Looks better to me than it was!
Off-road:
Normal:
Access mode:
Seems to handle much better now too!
Post #421390 6th Jan 2017 11:41am
you can check the heights yourself using this chart,
in standard the front should be 1cm higher than the back..
Post #421391 6th Jan 2017 11:51am
Stacker
There isn't a height for the stupid 22inch wheels that are on the car, I think we did it to 20. The guy said there wasn't much in it really!
Just measured the heights, perfect for 20inch wheels! Smile
Post #421394 6th Jan 2017 12:01pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I'm convinced mine is sitting too high.
Thanks for the above, been looking for that information for a few weeks now.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #421459 6th Jan 2017 5:23pm
Stacker
Post a picture and we can help you out!
I never even thought about mine sitting too high to be honest it's been like it since I got the car, on a Better note it does handle better now!
Post #421462 6th Jan 2017 5:44pm
Those measurements Stan put up are taken from the centre of the hub so regardless of size of wheel they will work . 2008 MY Supercharged
Post #421536 7th Jan 2017 2:35am
Yes, I put the chart together for different rims because IIRC the All Comms was taking measurements from the rim not the hub centre, if not i know there was a reason for it!
All cars should be the same from the hub centre though!
I have my rear end (ooer!) up by @ 15mm on standard height, never had any errors on that? .
Post #421557 7th Jan 2017 10:35am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
So do you set the heights using the calibration settings in the IID? Pretty convinced mine is sitting low at the rear and this was one of the next jobs to look at Smile
Cheers,
MM
Post #421578 7th Jan 2017 12:25pm
the rear is supposed to be 1cm lower than the front..
yes, the iidtool can adjust the heights but read the manual first, it's a bit complicated...
Post #421580 7th Jan 2017 12:31pm
Stacker
Tim - mine was about 50mm too high all around!
It was done using a Snap On Solus! Worked perfect!
Post #421592 7th Jan 2017 1:15pm
mm289
Just played with mine, initially FR = 500 FL = 520 RR = 470 RR = 490 so all over the place Shocked
Now adjusted it so we have it at 1 10mm drop from standard allround.
Only problem now is it has created a "pull to left" when driving - not sure how altering the ride heght could have done that unless the tyres have got uneven wear or something......
One more to the list to sort out Rolling Eyes
Cheers,
MM
Post #421614 7th Jan 2017 3:48pm
kbald
Was that the measurements on the iid app or from taking them manually?? If from the iid app they will be all different ?
Post #421625 7th Jan 2017 4:41pm
@ kbald
You don't get measurements from the IID Tool, you have to physically do it. IID Tool presents a sensor reading Which you adjust. They include a nice chart in the documentation or on the website to download when you intend to carry out a calibration.
@ mm289
Probably because you have two right rear wheels Laughing
Possibly if you had 4 wheel alignment done at those height settings, by calibrating you have put things out of kilter. Calibration is not something to "play" with ! You may need another alignment check, or you have an issue with bushes or tyres. Might be worth checking measurements again after a good run.... .
Post #421646 7th Jan 2017 7:00pm
kbald
Hi joe90 that's what I meant if he simply changed the settings using the iid tool it won't be right so he would need to e measure correctly as per the chart you produced. On the Bluetooth iid it gives you figures for the suspension on the app.
Post #421650 7th Jan 2017 7:40pm
mm289
yep, copious amount of measuring, then calibrated left to right but as the original measurements (measured from middle wheel to wheel arch) were so far out manually adjusted heights to get the car roughly square then recalibrated.
Then took for a run, remeasured to check it had retained the setting, then dropped 10mm all round.It has had numerous bushes done by PO but I have one annoying knock coming from front right which doesnt show itself when it is up on the 4 poster wheels in the air - once I have figured that one out I iwll do a final height check then put it in for a 4 wheel alignment Very Happy
@Joe - two RR wheels - well spotted Rolling with laughter just as well I used the charts from IID for doing the maths eh Thumbs Up
Cheers,
MM
Post #421658 7th Jan 2017 9:02pm
