![]() | Home > Technical (L322) > Stalled after water on road!!! |
Your fault is possibly nothing to do with water, when did you last change the fuel filter? |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Today it stalled again.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 752 ![]() ![]() |
Have you changed the fuel pump yet?
No i di not change yet.
As the others have said it sounds like your low pressure pump is at fault so the problem will not go away until you change the pump. |
So not the one in the tank i guess. |
The pump in the tank was faulty.
To give some useful info if your car stalls time to tim after some loss of power,in-tank pump faulty not front pump.
