![]() | Home > Technical (L322) > 2006 side-light/headlight bulbs?? |
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 ![]() ![]() ![]() |
Cornering lights. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
as i have done Glen, you can adjust the headlights up a bit so the light spread is better...
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
Could be. Do they only come on when turning? |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Does yours have the separate indicator unit? |
Stan, Yes, I was contemplating adjusting them up before I realised that these other bulbs were there. It has just been MOTed but it seems that most garages adjust them down, if they are too high but not up, if they are too low. The primary main bean and dip head-lights are xenon, so no possibility of a bulb upgrade, and with the xenons it shouldn't need them. |
Indicators are above the side-light but still in the main front light housing. |
Yes, on cars without the cornering light there is a chrome blank in place of the bulb. |
Just found out that the xenon bulbs can be replaced, I didn't realise, I though that they were a sealed unit. Have found some Osram Nightbreaker bulbs that claim to give 70% more light, so, if adjustment doesn't work, these will be the next option. |
Looks like both the cornering light bulbs might be blown, as with the car running and stationary, turning the wheel from lock to lock does not make them illuminate. |
