Home > Maintenance & Mods (L322) > Fuel Gauge erratic |
Haydn Member Since: 10 Oct 2016 Location: Sussex Posts: 10 |
Hi i have a L322 MY10 TDV8 and went on a longish run put £50 in and the gauge read just over 1/2 did a few miles looked at the dash and the gauge read less than 1/4 i pulled over thinking i was possibly loosing fuel (well more than normal and nothing, waited a few minutes restarted and the level came back up
1st Jan 2017 5:28pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'm not so sure that the tank has to be dropped, cos unless there has been a radical redesign on the later ffrr's there are 2 access panels under the rear seats that allow you to get at the sender's and the fuel tank pump Yesterday I couldn't spell Engineer... Today I are one!
1st Jan 2017 6:57pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8540 |
There are 2 in tank senders, one in each section of the tank, and the dash takes an average of the 2 if one packs up then the needle goes haywire.
1st Jan 2017 7:06pm |
I think you'll find that the pump unit side can only be had with the pump from LR.. that's not to say that there isn't some one out there doing separate ones... after all you can get the pump on it's own, just not for a Range Rover Yesterday I couldn't spell Engineer... Today I are one!
1st Jan 2017 7:20pm |
I think as a LR part it is the entire pump and senders, which is what I got from LR direct, I seem to remember finding out afterwards that the sender units were possibly available separately.
1st Jan 2017 8:54pm |
Paddyc Member Since: 30 May 2016 Location: Antrim Posts: 13 |
Exactly the same thing happened to my tdv8 my2010 - the sender and the fuel pump are one part and were only available from LR. It cost about 400ish for the sender and about two hours of labour - total bill was 540 all in including vat at a LR specialist |
2nd Jan 2017 1:15am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3813 |
Mine does this occasionally so just in case I zero the trip when I fill up and fill up again just after 300mls - the only inconvenience to owning a 5.0L SC.
2nd Jan 2017 5:14pm |
Well I've booked in to an independent after my local main dealer didn't return my calls, the gent at Paul Rutter's Land Rover Bognor Regis said it's wiring he's done 6 range rovers all the same problem corrosion on the pump and it's not covered under warranty so i called RAC warranty they said no wiring is not covered, man at the garage said the tank has to be dropped and quoted 2-£300 I didn't argue the sender or that pump can be accessed under the rear seats as I believe it's only the earlier models that require the tank dropping out, it's going there today as I need to drive to Manchester the weekend and need it asap but I'm going to hang around at the garage and watch the process and will let you know the outcome |
4th Jan 2017 6:26am |
Got the car back all fixed I was told it was the connectors on the harness to the senders aparekntly L
4th Jan 2017 7:32pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
I bought my 2010 TDV8 in the summer and was told that the dealer had problems with an erratic fuel gauge, which he'd had fixed. He'd been using it as his own car for a few months.
4th Jan 2017 7:45pm |
My out come of this problem was apparently a common one if you get this issue advise your local dealer you are aware there is a fix on the sender harness where the old connect is removed and a new inline connector to extend the length of the harness |
7th Jan 2017 9:34am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
I'm having an issue here also, gauge says empty, but I'm filling max 75 litres. So 100 litre tank is actually 1/4 full.
25th Feb 2017 12:17am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1425 |
Not for free 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
25th Feb 2017 8:14am |
Found the bulletin:
26th Feb 2017 9:58am |
