Home > Maintenance & Mods (L322) > Help Needed - Fast Flashers - |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7921 |
It does sound like there isn't enough load on the circuit.
31st Dec 2016 8:44am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Sounds to me like there is a floating earth fault.... I think you need to retrace the wiring, it sounds to me as the DRL's are earthing through the flashers... what happens to the angel eyes when the flashers are on? do they flash too? Yesterday I couldn't spell Engineer... Today I are one!
31st Dec 2016 2:32pm |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 |
Hey thanks for the reply! Yes I think I will try and first stick in both side light bulbs and then try the indicators again. Then perhaps buy bigger bulbs and fit those and see if that makes a difference. I'm not sure if adding big bulbs or bulbs at all to the side light slot will make a difference in the indicator flashing as it's a completely separate wire, it will make the side light error go away of that I'm certain. Yeah I was really disappointed, the front led boxes I think are working as they should because I can hear the relay go off when the blinkers are on; but I don't hear any real system in the rear led boxes. Zambezi Silver Range Rover (2010 Autobiography Facelift) Mercedes Benz GL450 4Matic (X164) Mercedes Benz E500 4Matic (W211) (Sold) Mercedes Benz 300SDL (W126) Lexus LX470 (J100) Audi A8L (D3 Chassis) |
31st Dec 2016 6:19pm |
Hey thanks for the reply; the angel eyes don't get affected at all when the indicators are on. I did a bit of reading and it turns out that my older 2004 model is not programmed to run the LED's as DRL's. Basicslly they are wired in as the parking light. And I should have followed all the wiring perfectly for sure because all the functionality is there except the fast blinking indicators. I heard there is something you can purchase that changes the high beam acting as your drls to your led drls acting as your drls, apparently a lot of hondas and toyotas that are upgraded with leds also suffer with the same problem. Zambezi Silver Range Rover (2010 Autobiography Facelift) Mercedes Benz GL450 4Matic (X164) Mercedes Benz E500 4Matic (W211) (Sold) Mercedes Benz 300SDL (W126) Lexus LX470 (J100) Audi A8L (D3 Chassis) |
31st Dec 2016 6:24pm |
I'm slightly cautions as I have no idea what the LED interface units are or how they are wired.
31st Dec 2016 6:39pm |
These are the rear LED Units I purchased: http://www.ebay.ca/itm/162305059479?ul_noapp=true
31st Dec 2016 7:04pm |
What did you use for the front lights ? |
31st Dec 2016 7:18pm |
Similar box for the front except it had room for a 5 AMP fuse in one of it's wires and it had to be hooked up directly to the battery. Zambezi Silver Range Rover (2010 Autobiography Facelift)
31st Dec 2016 7:59pm |
Not sure what the permanent power would be for on the fronts.....
31st Dec 2016 8:05pm |
Yeah a few months ago I contacted him, once the talk of me returning the rear light led units came and getting another pair from him, he disappeared from his email account ahaha. I messaged him today again via eBay and he did respond, I shortly messaged him pictures through his email and yet again he is disappeared from his email account. I think I get his message. Zambezi Silver Range Rover (2010 Autobiography Facelift)
31st Dec 2016 10:19pm |
I am thinking of adding a relay system to the rear tail lights, but I am not sure if I would need to run a 12v source all the way from the battery for the relay system. I also looked at the relay panel in the back where the fuses also are, there is room for a relay (actually room for 3 relays) but don't know if any of them correspond to the indicators. Traditionally vehicles have their indicators managed using a relay flasher module, but don't know if that's the case for our L322's. Zambezi Silver Range Rover (2010 Autobiography Facelift) Mercedes Benz GL450 4Matic (X164) Mercedes Benz E500 4Matic (W211) (Sold) Mercedes Benz 300SDL (W126) Lexus LX470 (J100) Audi A8L (D3 Chassis) |
31st Dec 2016 10:42pm |
Relays will not cure the problem, they will make it worse... the LCM is looking at the different light circuits and measuring the amount of amps that are being drawn... LED's use a lot less amps and therefore the LCM thinks that there is a bulb blown and then all the blinking lights and Bongs and messages start
31st Dec 2016 11:47pm |
Hey miggit thanks for the reply! Okay so I am in luck, I have the non-touch screen! I'll place and order on that dongle right away. Also question for you, does it make a difference if you wire in the load resistors for both left and right sides of the vehicle at the same time or do it just on one of the sides to check the indicator flash rate. Because I'm assuming the left side indicator circuit runs independently of the right side circuit, so in other words a load on the left side won't make a difference on the indicators on the right side. Zambezi Silver Range Rover (2010 Autobiography Facelift)
1st Jan 2017 5:51pm |
If your adding load resistors then they need to be around 35 watts each and you'll need to add one at each indicator that has been changed to LED.. However those rear light adaptor boxes are normally OK so I would look at just doing the front lamps to start with... having said that you can get load (ballast) resistors 10 a penny... well more like under $5 for a pair Yesterday I couldn't spell Engineer... Today I are one!
1st Jan 2017 6:13pm |
