Home > Technical (L322) > Please listen and see if you can help? |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I'm still having problems getting my V8 running as I want, so I've taken some video and put it on youtube to see if any of you guys can come up with any suggestions.
12th Dec 2010 4:36pm |
hmmm, no idea myself... Do you have any BMW specialists near you? Personally I wouldnt let a LR tech near the BMW engine if it involves a top end re-build... |
12th Dec 2010 4:47pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Sounds like something in the top end (suggesting cam etc).
12th Dec 2010 5:04pm |
It sounds like it's coming from the drivers side of the engine. The mechanic I would be getting to look at it is an independent who runs the l322 4.4 with lpg as his personal car, so I am quite happy that he knows the engine well. He's also an lpg convertor, and works on vehicles sent to him by the local main dealer (as they won't touch any lpg vehicles).
12th Dec 2010 6:24pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
it sounds like the tappets to me and may be a bit cam as well, when you come of the throttle the tappets can be heard..you cant make a diag from a video but it does give some idea, if you were going to attempt to find out what the prob is, i would as mentioned,,, use a long screw driver of stethoscope and find out what ones are making the noise, hot and cold.. then whip of the covers and check these ones..look at the cam lobes to see if there is extensive were, could be an oil starvation prob at some point. V8 facelift Range Rover Autobiography 22" wheels.
12th Dec 2010 8:49pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
my ff has developed a slight rattle when you de accelerate but i dont get the rattle like yours or anywhere near as loud.....i was thinking maybe the tensioners "RANGEISM WILL NOT BE TOLERATED"
9th Jun 2011 12:48pm |
