Home > Technical (L322) > Auto lamps just stopped working (2011 4.4TDV8 Autobiography)
Webbie
The auto position on my lights has just stopped working. Turning the sidelights or main beam on manually, all works fine. I can't see a fuse for the auto light function detailed in my handbook, so presume it must be not be intended for "owner maintainance". If anyone can help with the problem it would be much appreciated.
Inceidently, the car has an historic problem of blowing the front fog lights fuse, also the front windscreen wipers have parked too high for some time. I mention these just in case there is some connection with the auto lights control.
Post #420169 30th Dec 2016 2:14pm
the auto lights work from a sensor behind the interior mirror, i suspect that has gone kaput ..
Post #420173 30th Dec 2016 2:42pm
Webbie
Thanks to the reply, looks expensive. Does anyone know if there is a fuse to check before replacing the sensor?
Post #420175 30th Dec 2016 2:51pm
theres a fuse box behind the glovebox, have a look at the diagrams on the cover and see if anything there is relevant.... ... - .- -.
Post #420182 30th Dec 2016 3:44pm
