Home > Technical (L322) > Auto lamps just stopped working (2011 4.4TDV8 Autobiography) |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
The auto position on my lights has just stopped working. Turning the sidelights or main beam on manually, all works fine. I can't see a fuse for the auto light function detailed in my handbook, so presume it must be not be intended for "owner maintainance". If anyone can help with the problem it would be much appreciated.
30th Dec 2016 2:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35292 |
the auto lights work from a sensor behind the interior mirror, i suspect that has gone kaput ..
30th Dec 2016 2:42pm |
Thanks to the reply, looks expensive. Does anyone know if there is a fuse to check before replacing the sensor? |
30th Dec 2016 2:51pm |
theres a fuse box behind the glovebox, have a look at the diagrams on the cover and see if anything there is relevant.... ... - .- -.
30th Dec 2016 3:44pm |
