![]() | Home > Technical (L322) > Burning clutch smell |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
My first thought with burning smells is that the brakes might be sticking, are any of the wheel centres warm/hot after you have been driving? The rear brakes only come on under heavy braking or when the car is heavily loaded and are prone to this, changes of pads without the pistons being clean enough or where the dust seals are damaged can cause it too.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35655 ![]() ![]() |
as look at the FF from the front , it could be the fbh... ... - .- -.
aneurysm1 Member Since: 12 Dec 2012 Location: burnley Posts: 202 ![]() ![]() |
There was a bit of white looking smoke when I first noticed it, but that disappeared as quick as it arrived and hasn't happened all day. Now the smell is still slightly there but zero smoke........ |
Madmax676 Member Since: 25 Jun 2016 Location: Somerset Posts: 44 ![]() ![]() ![]() |
Agree with the above - try brakes first. Take it for a long drive then squirt water on all 4 wheels - they will all steam a bit but the very hot one will be like a volcanic vent hole |
