Home > Technical (L322) > Burning clutch smell
aneurysm1
2010 Range Rover Autobiography TDV8 Cairns Blue
Can you educated folk give me a clue on what the problem would be if I can smell 'burning clutch' from the right side exhaust?
Post #418678 19th Dec 2016 6:44pm
CS
My first thought with burning smells is that the brakes might be sticking, are any of the wheel centres warm/hot after you have been driving? The rear brakes only come on under heavy braking or when the car is heavily loaded and are prone to this, changes of pads without the pistons being clean enough or where the dust seals are damaged can cause it too.
Do you have a DPF? That can cause smells out of the exhaust too, if you stop while it is burning off filtrates. Only Range Rovers since 1988
Post #418694 19th Dec 2016 7:45pm
as look at the FF from the front , it could be the fbh... ... - .- -.
Post #418701 19th Dec 2016 8:10pm
aneurysm1
There was a bit of white looking smoke when I first noticed it, but that disappeared as quick as it arrived and hasn't happened all day. Now the smell is still slightly there but zero smoke........
Post #418711 19th Dec 2016 9:28pm
Madmax676
England 2003 Range Rover Vogue 4.4 V8 Java Black
Agree with the above - try brakes first. Take it for a long drive then squirt water on all 4 wheels - they will all steam a bit but the very hot one will be like a volcanic vent hole
Post #419919 28th Dec 2016 10:57pm
