Home > Technical (L322) > Can I Replace the std door mirror with an Electrochromatic |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
Hi. I have to replace the whole of the drivers door mirror on my 03 TD6 Vogue and I dont think the one currently on the car is Electrochromatic (I could be wrong). Apart from the dimming facility not working, is there any reason (electrical connectors different etc) why I couldn't use an Electrochromatic one if that was the only replacement available? QUID FACIUM TIBI
28th Dec 2016 8:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
You won't want to when you see how much they are...!!! Pete
28th Dec 2016 8:30pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
Do the electrochromic mirrors have a pale blue tinge?
28th Dec 2016 9:09pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
You can get aftermarket ones for about £55 each rather than the LR branded ones at more than twice the price. Just search for the LR part number in google and it should come up. Tom
28th Dec 2016 10:27pm |
From my research the std ones are pale blue and the electro ones are brownish - is that correct? I am looking at an example of each that are virtually the same price but the electro one is in better nick. I just wondered if the plugs would not fit in the sockets if mine wasnt electro and I tried to fit one. Its will look up the vin tomorrow..... QUID FACIUM TIBI
28th Dec 2016 11:32pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Don't know about earlier models but on my 07 there are separate plugs for the heating element and elecrochromatic dimming. Worth bearing in mind that the entire system uses a sensors in the central rear view mirror - unless your vehicle already has electrochromatic dimming mirrors, I don't believe you can 'upgrade' easily. 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
29th Dec 2016 12:04am |
recoverytim Member Since: 28 Mar 2016 Location: Exeter Posts: 27 |
I had electro chromatic on my vogue, but when one started going misty from moisture between the layers I changed to standard glass as the e/c mirror glass was nearly £200 plus VAT from Land Rover, and around £140 plus VAT aftermarket!!
29th Dec 2016 6:52am |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 |
Having just recently clipped a wheelie bin and broken a door mirror glass, I too was stunned with prices up to £273, yes just for the glass the whole mirror is over £700
30th Dec 2016 7:47am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Just read up on fbhin the wiki.
30th Dec 2016 6:46pm |
Ginja Member Since: 17 Mar 2016 Location: England Posts: 26 |
Yes, thread resurrection...
24th Nov 2017 1:35pm |
