Home > Technical (L322) > Can I Replace the std door mirror with an Electrochromatic
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Hi. I have to replace the whole of the drivers door mirror on my 03 TD6 Vogue and I dont think the one currently on the car is Electrochromatic (I could be wrong). Apart from the dimming facility not working, is there any reason (electrical connectors different etc) why I couldn't use an Electrochromatic one if that was the only replacement available? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #419892 28th Dec 2016 8:14pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
if you PM me your VIN i can let you know if you have the electrochromatic mirrors fitted.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #419897 28th Dec 2016 8:24pm
You won't want to when you see how much they are...!!! Pete
Post #419900 28th Dec 2016 8:30pm
p38arover
Australia
Do the electrochromic mirrors have a pale blue tinge?
I'm also interested as I was given such a driver's mirror assembly by a friend and I don't know whether to fit it. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #419911 28th Dec 2016 9:09pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
You can get aftermarket ones for about £55 each rather than the LR branded ones at more than twice the price. Just search for the LR part number in google and it should come up. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #419924 28th Dec 2016 10:27pm
Spelunker
From my research the std ones are pale blue and the electro ones are brownish - is that correct? I am looking at an example of each that are virtually the same price but the electro one is in better nick. I just wondered if the plugs would not fit in the sockets if mine wasnt electro and I tried to fit one. Its will look up the vin tomorrow..... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #419932 28th Dec 2016 11:32pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Don't know about earlier models but on my 07 there are separate plugs for the heating element and elecrochromatic dimming. Worth bearing in mind that the entire system uses a sensors in the central rear view mirror - unless your vehicle already has electrochromatic dimming mirrors, I don't believe you can 'upgrade' easily. 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #419935 29th Dec 2016 12:04am
recoverytim
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I had electro chromatic on my vogue, but when one started going misty from moisture between the layers I changed to standard glass as the e/c mirror glass was nearly £200 plus VAT from Land Rover, and around £140 plus VAT aftermarket!!
Yes, there is a two pin blue connector for the function, about 4mm X 4mm X 10mm, and the glass appears to have a light brown tint to it. To be honest, although a nice feature, not having it on the wing mirrors but still having it on the rear view, I can see a difference but it's not massive- unlike the price!
Post #419948 29th Dec 2016 6:52am
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
Having just recently clipped a wheelie bin and broken a door mirror glass, I too was stunned with prices up to £273, yes just for the glass the whole mirror is over £700 Shocked
Bearmach have an electrochromatic replacement which resellers are asking a mere £70 for.
Post #420113 30th Dec 2016 7:47am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Just read up on fbhin the wiki.
Apparently there is a outside air temperature sensor in the mirror n/s, for the fbh to work.
Thought I'd mention it, as replacement second hand could be off a petrol, and not many of those came with fbh.
Post #420231 30th Dec 2016 6:46pm
Ginja
Yes, thread resurrection...
Wondered if anyone could advise how hard it would be to add the auto dimming wing mirrors to my 2012 Westminster TDV8 which does have a electrochrome interior mirror?
Driving a lot at night and noticing the sheer volume of cars with lights out of alignment which is bad when they are traveling in the opposite direction but even worse when they are stuck to the back of you!
Thanks!
Post #458427 24th Nov 2017 1:35pm
