Home > Technical (L322) > Rear wheel alignmentd |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Further to my post about my car handling like I've found the problem, took it to have a 4 wheel alignment the other day to be told my rear wheels were 1.6mm out both sides, that explains a lot.
24th Dec 2016 7:28pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
The toe link and the upper hub bush both have eccentric bolts, therefore both may need adjusting for correct alignment.
25th Dec 2016 12:42am |
Thanks for the reply as always
25th Dec 2016 1:01am |
Oh god that sounds like a horror story!
25th Dec 2016 10:23am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
This was the very helpful thread i followed
25th Dec 2016 11:46am |
Thanks for your help
25th Dec 2016 12:50pm |
You should be able to find the parts easily, don't forget you needs nuts bolts and washers and give the bolts a good grease up before putting them back through the bush
25th Dec 2016 1:30pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8064 |
Don't be tempted to use pattern parts, they fail very quickly, get genuine or OEM. Dan at Duckworths will sort you a good price on OEM parts as well as Genuine...
25th Dec 2016 9:07pm |
If the dealer doesn't have them in stock they are easily able to get them next day, they are about £12-14 per bolt with washers and nut.
27th Dec 2016 11:10am |
