Home > Maintenance & Mods (L322) > Loose side vent?
Rob99
Loose side vent?
Took the Westie to Wales and back yesterday, faultless trip but noticed some wind noise and a slight rattle coming from front drivers side. Had a look and nothing obviously loose but the side vent doesn't seem as solidly fixed as the passenger side one so I'm thinking maybe it just needs refitting and/or maybe a broken trim fixing.
Can someone tell me how the side vent side are fitted and are they easy to remove and refit. Don't want to start yanking them off and end up snapping something vital.
Cheers 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #419258 23rd Dec 2016 8:22am
here you go Rob,
Post #419260 23rd Dec 2016 8:49am
Roystonh
Had that in mine, dealers didn't find the noise and only realised when I had my vents changed. 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #419261 23rd Dec 2016 9:06am
Stuart
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Had a rattle on mine, only at 50+ mph, and thought it was the side vent. It wasn't.
It eventually occurred to me that the noise only started after I'd had a new windscreen fitted, and it turned out to be the side trim on the windscreen. I could get hold of it and peel it away from the windscreen, but obviously couldn't see it moving at 50 mph.
Worth investigating?
Post #419264 23rd Dec 2016 9:26am
Rob99
stan wrote:
here you go Rob
Thanks Stan, very useful. Thumbs Up Will give me an excuse to get away for a few minutes peace over Christmas..... Laughing
@stuart.....haven't had windscreen replaced but will check trims anyway. 2021 D350 Fifty Edition - Carpathian Grey
Post #419317 23rd Dec 2016 3:15pm
Stuart
Hope you get it sorted, Rob.
Post #419330 23rd Dec 2016 5:07pm
RobsterPC
I had a rattle in mine at 50+ mph. I took the vent off to have a look and noticed that the fit between the painted and black plastic trim wasn't great, the two could rattle into each other. I separated the two parts, its simply pushing down three retainint tabs to release them. Then I put some 3M double sided padded tape on the parts that I thought would rattle, reassembled and re-installed. It took around 5 minutes to complete.
A quick test drive and voila, no more rattle at 50+ mph.
Post #703711 4th Nov 2024 9:43am
