![]() | Home > Maintenance & Mods (L322) > Loose side vent? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1455 ![]() ![]() |
Took the Westie to Wales and back yesterday, faultless trip but noticed some wind noise and a slight rattle coming from front drivers side. Had a look and nothing obviously loose but the side vent doesn't seem as solidly fixed as the passenger side one so I'm thinking maybe it just needs refitting and/or maybe a broken trim fixing.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
here you go Rob,
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 ![]() ![]() ![]() |
Had a rattle on mine, only at 50+ mph, and thought it was the side vent. It wasn't.
Thanks Stan, very useful. ![]() ![]() @stuart.....haven't had windscreen replaced but will check trims anyway. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Hope you get it sorted, Rob.
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 121 ![]() ![]() |
I had a rattle in mine at 50+ mph. I took the vent off to have a look and noticed that the fit between the painted and black plastic trim wasn't great, the two could rattle into each other. I separated the two parts, its simply pushing down three retainint tabs to release them. Then I put some 3M double sided padded tape on the parts that I thought would rattle, reassembled and re-installed. It took around 5 minutes to complete.
