Home > Maintenance & Mods (L322) > Interior light dimming on abrupt stop |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Is your vaporiser mounted front to back or side to side? if side to side i.e from the front of the car you see the round front or back and not the thinner side of it, then as you brake the diaphragm inside will move under negative G and starve the engine of LPG causing the revs to drop... Common problem with badly fitted systems...
19th Dec 2016 12:31pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Hey Pete - ill check it out this afternoon..
20th Dec 2016 12:49pm |
Hey Pete - as the say a picture is worth a thousand words... what do you reckon?
20th Dec 2016 1:29pm |
Yep, that's bad... needs moving... this is about as far off straight as you want...
20th Dec 2016 5:41pm |
