Yep, that's bad... needs moving... this is about as far off straight as you want...
6mm pipe will not flow enough LPG, I have been playing with the engine map in mine, increased the ignition advance to suit the much higher octain of LPG, this has made a noticeable increase in power but it now changes to petrol on full acceleration in the lower gears as I'm not getting enough LPG down an 8mm pipe....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Pete
