Home > Technical (L322) > How to Find Top Dead Center TDV8 |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1775 |
Does SDD return any "pending" or "Not Tested" codes? |
17th Dec 2016 8:01pm |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
So, I made this video tonight to show you all what is happening.
19th Dec 2016 10:24pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 354 |
I really hope I'm wrong and its just the video that makes it appear to be but that sounds to be spinning very fast - missing some compression in a few cylinders. The bit where i think you say its nearly starting to me sounds like its actually slowing a little due to the resistance of compression in good cylinders.
19th Dec 2016 10:41pm |
I hope you are wrong too! No panic however, what will be will be.
19th Dec 2016 10:45pm |
if it doesn't run on that awful stuff then i think you've got some major problems. Current
19th Dec 2016 11:02pm |
I just find it so hard to believe it could fail like that. She was running perfect for 30 miles, then just stalled out pulling out a car parking space! Like a chain can't slip?
19th Dec 2016 11:22pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I think I'd be doing a compression test before I did anything else, if nothing else just to rule it out. |
20th Dec 2016 12:07am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Has the immobiliser code fault been rectified now ?
20th Dec 2016 6:26am |
I'm going to try and get a compression test done over the next number of days. How it could have failed without a big bang is beyond me. I really hope it is OK.
20th Dec 2016 9:44am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I'm thinking some kind of immobiliser problem. Have you spoken to Gap to see if they can help? ______________________________
20th Dec 2016 9:47am |
I hope you are right RAR110. I'm going to email them today. I couldn't get the IID tool to read the live values from the Engine. Perhaps this is a sign of bad communication. |
20th Dec 2016 9:49am |
can you check if you are getting fuel ? |
20th Dec 2016 11:37am |
I can smell fuel out the back and see some white smoke? I'm going to undo one of the injectors next and see if they are getting fuel. Likewise, I'm going to do a compression test. Hopefully all will be well. |
20th Dec 2016 12:21pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 55 |
As an ex diesel tech, it sounds to me when it's turning over as though it only has compression on one cylinder.
20th Dec 2016 3:58pm |
