Home > In Car Electronics (L322) > Which BT module do I need? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 354 |
bluetooth module has been removed.
7th Dec 2016 10:20pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Cheers, thats what I figured had happened.
7th Dec 2016 10:30pm |
Imo if you have no module currently going straight to the latest one as fitted in the 2010 disco4/res/fullfat is he best way to go 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Dec 2016 10:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
theres a list of BT module numbers in the wiki .. ... - .- -.
8th Dec 2016 9:31am |
Thanks Stan, I have looked at that but assumed it was relevant to the replacement/upgrade of the pre MOST systems as it was referenced from a lot of these threads.
8th Dec 2016 12:17pm |
LR025842 is the part you need. Current
8th Dec 2016 12:43pm |
Thanks Andy,
8th Dec 2016 1:20pm |
If you go through Wiggs there is no surcharge. You just buy the unit and he gives you a little cable to power it. Think it's about £240ish unless they've gone up.
8th Dec 2016 4:37pm |
Just thought I would post an update for anyone else looking at this.
20th Dec 2016 11:13am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Thanks for the info MM.
20th Dec 2016 4:53pm |
Jono843 Member Since: 16 Jan 2017 Location: Mansfield Posts: 3 |
Hi, sorry to hijack the post.
16th Jan 2017 12:14pm |
Do you have to redo the 2121 every time you enter the car?.
16th Jan 2017 6:56pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Jono, As Greg says, I think that you need to reflash the BT module. Needs something like the iiD tool to do it. John
16th Jan 2017 7:00pm |
Hi gregdav and weegie, thanks for your reply. Yes I do have to enter 2121 every time I sync and there is no phonebook/contacts. It will connect fine but the clarity of sound in the cab is very muffled and inaudible. I've priced up the iid module and nearly shat myself lol I understand that wiggs does a Bluetooth exchange but I'm not sure if this upgrade will cure the sound issue. Iid module may cure this but I can't afford to buy one unfortunately. Is there anyone out there who can do this for a fee??? I can travel |
16th Jan 2017 7:34pm |
