Home > In Car Electronics (L322) > Which BT module do I need?
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Looking to install/reinstate bluetooth in the FFRR. It is a late 2005 Vogue SE with the touchscreen infotainment system (MOST?).
Looks like it has had a factory phone install as it has the cradle in the centre armrest but no BT when I search with my phone.
Having read most of the threads on here re retrofitting BT and looking at the pic below of mine, I am guessing the phone module has been removed and the fibre optics joined to take it out of the loop.
Does this seem logical/likely and if so what module do I need to reinstate (have seen a few post about retrofitting a later BT module?)
Cheers,
MM
Post #417064 7th Dec 2016 9:13pm
andygts
bluetooth module has been removed.
The fibreoptic (MOST) wire with the white lining has an inline connection to bypass the module if you look at the picture just above the DVD drive.
If you have a fish around you should find another plug floating about somewhere which powers the unit.
You are better off emailing Wiggs at http://bluetoothexchange.co.uk/ and get the newer style module (its not listed on his site but he can get them)
The phone cradle is redundant these days unless you still use an old nokia brick then I doubt you'll find a cradle to fit, just the bluetooth is used. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #417068 7th Dec 2016 10:20pm
mm289
Cheers, thats what I figured had happened.
Will ping an e-mail to Wiggs, to see what the options are Very Happy
MM
Post #417072 7th Dec 2016 10:30pm
Imo if you have no module currently going straight to the latest one as fitted in the 2010 disco4/res/fullfat is he best way to go 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #417073 7th Dec 2016 10:40pm
theres a list of BT module numbers in the wiki .. ... - .- -.
Post #417099 8th Dec 2016 9:31am
mm289
Thanks Stan, I have looked at that but assumed it was relevant to the replacement/upgrade of the pre MOST systems as it was referenced from a lot of these threads.
I guess in reality though it is the same unit so works for both MOST and BMW systems?
cheers,
MM
Post #417119 8th Dec 2016 12:17pm
andygts
LR025842 is the part you need. Current
Previous
Post #417122 8th Dec 2016 12:43pm
mm289
Thanks Andy,
challenge is I don't have the original so will have to pay the surcharge as well circa £100, Sad
Makes it £400+ all in!
Cheers,
MM
Post #417130 8th Dec 2016 1:20pm
andygts
If you go through Wiggs there is no surcharge. You just buy the unit and he gives you a little cable to power it. Think it's about £240ish unless they've gone up.
Guessing you've rung the steelers for a price? Current
Previous
Post #417157 8th Dec 2016 4:37pm
mm289
Just thought I would post an update for anyone else looking at this.
Contacted Adrian (Wiggs) at Bluetooth exchange and ordered the later unit - it was £240 delivered as suggested.
Arrived very quickly and followed the instructions which are literally as simple as pluging in the MOST cables (Adrian sent me a new connector as well as mine had been removed) and pushing the +ve and -ve feed into the old multiconnector. Took about 5 mins!!
Initially it wouldn't show a BT for me to connect to even though the unit was powered up so pinged ADrian for advice. Responded within an hour (on a Sunday evening Shocked ) to suggest checking that BT was enabled in the car config files.
Plugged in IID and yep, BT had been disabled! Changed to enabled and hey presto - LandRover appeared as a BT option on the phone. Also worth noting the "Cellular Telephone" option in the CCF should be set to "Cellular Telephone - cellular telephone docking station , with bluetooth" according to Adrian. Mine was set to "Telematics" - not sure what the diffierence is Rolling Eyes
Anyway, all now working, address book synced etc - can't recommend Adrian/Bluetooth exchange enough, really helpful and easy upgrade. £240 may seem a lot for the module but I use the Rangie for work and the convenience of built in handsfree is well worth the money.
Cheers,
MM
Post #418782 20th Dec 2016 11:13am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Thanks for the info MM.
Especially the info on ccf, didn't know that.
Greg. Thumbs Up
Post #418846 20th Dec 2016 4:53pm
Jono843
England 2005 Range Rover Vogue Td6 Tonga Green
Bluetooth clarity 2005 l322
Hi, sorry to hijack the post.
I'm having a problem with the Bluetooth in my 2005 l322 td6. I have the iPhone 5 which connects to the Bluetooth fine using 2121 but no contacts etc.. I understand there's a mod I can do to upgrade that (Bluetooth exchange). My issue is that although my phone connects and it takes and makes calls however the incoming call clarity is very muffled and i can't hear them properly, the caller hears me fine..
any ideas please??
Ps my tv tuner box is not plugged in due it failing, the fibre optics to it have been properly connected
Many thanks
Post #423034 16th Jan 2017 12:14pm
gregdav
Do you have to redo the 2121 every time you enter the car?.
If so sounds like you need an update on the blue tooth unit.
since updating mine, the car automatically syncs my phone, which is a I phone 4s.
the phone contacts are on the screen. The only thing I don't get, is the up and down on the steering binnacle for sorting contact list.
everything else is fine, in fact brilliant.
Iid tool will do the update, can't recommend this piece of wizardry too much.
Post #423119 16th Jan 2017 6:56pm
Weegie
Jono, As Greg says, I think that you need to reflash the BT module. Needs something like the iiD tool to do it. John
GAP iiD BT
Post #423121 16th Jan 2017 7:00pm
Jono843
Hi gregdav and weegie, thanks for your reply. Yes I do have to enter 2121 every time I sync and there is no phonebook/contacts. It will connect fine but the clarity of sound in the cab is very muffled and inaudible. I've priced up the iid module and nearly shat myself lol I understand that wiggs does a Bluetooth exchange but I'm not sure if this upgrade will cure the sound issue. Iid module may cure this but I can't afford to buy one unfortunately. Is there anyone out there who can do this for a fee??? I can travel
Post #423136 16th Jan 2017 7:34pm
