Home > Technical (L322) > TDV8 Turbo failure
Mikey
TDV8 Turbo failure
Recovered in this week making a funny squeaking noise from the NS
Downpipes off, spin turbo by hand. Feeling an odd tight spot when spun
Strip turbo off to find this:
For clarity, car has 120k miles, serviced 6 weeks previously using Shell Helix Pro oil and OEM filters. EGRs were replaced 2 weeks previous (no EML, but a rough idle for 45 secs upon warm restart, the OS Valve very slightly out of sync...)
Post #418334 17th Dec 2016 6:28pm
rar110
Any idea what's fallen into the turbo? What on the blades to the right or is that blade damage? ______________________________
Post #418351 17th Dec 2016 8:16pm
Mikey
Blade damage. Would appear that the shaft is slightly bent
No foreign objects that I can see, no evidence of oil passing the seals on either side
Was a fairly low speed failure (allegedly) when cold, pulling out a junction and went pop
Post #418355 17th Dec 2016 8:29pm
billsmith737
England 2009 Range Rover Vogue TDV8 Santorini Black
Has anyone elses sphincter just got incredibly tight.. Shocked Shocked Rolling Eyes
Ive just had my sleeples nights over possible acctuator failer cured with the find of a split hose!.......my condolences .
Post #418366 17th Dec 2016 10:09pm
rar110
Thanks. Bending the shaft and the blades like must mean something has gone through the turbo. Would that something or remnants of it, be now sitting in the intercooler or feed pipe? ______________________________
Post #418376 17th Dec 2016 10:51pm
rar110
Here's a pic of the air system on a 3.6 from the WSM, which might help this discussion.
Post #418377 17th Dec 2016 10:55pm
Mikey
It did have a split turbo hose just a few months ago, too, incidently. Must ask the owner which hose had split Idea
Post #418394 18th Dec 2016 7:38am
rar110
Something has entered the turbo intake to cause that. I can't think of another explanation. There's not much between the filter box and the turbo.
I'm wondering if the air filter had been neglected long term and started to disintegrate or if the filter had been carelessly fitted and a piece of the foam edge has broken off and been sucked into the turbo. Or maybe someone has lost a filter box screw which dropped into the filter folds, only to be eventually sucked into the turbo.
I'm not really concerned about this type of failure. A basic level of competence and care negates the risk of the above possible causes. ______________________________
Post #418539 18th Dec 2016 8:37pm
