Home > LPG > lpg no tickover when starting
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
hi every time i start my hot engine she fires right up and promptly cuts out again. this has been going on for at least 2 years. also eml on when running on lpg. however if i give her a rev when starting all is good. she is running perfectly fine otherwise my lpg system is a king unit dont know if they are all that great not sure but i have done over 30000 miles with only this small niggle have had her serviced new filters etc but she still cuts out. tried cleaning injectors . made no diff . i am getting around 19 mpg 23mpg on motorway so she is pretty cheap to run i have also tried unplugging ecu . no diff . i found a split pipe on air intake fixed that and thought i had cured it but no . any ideas would be appreciated .
as an afterthought all owners of older l322 should check brake pipes under plastic cover running from back to front . i just had an mot done and we found these pipes were very corroded and an accident waiting to happen. i was very fortunate and quite lucky to find this as we had done a repair behind petrol tank cover had it all back together bled ready to roll when we seen damp patch seeping from behind cover further up line a bit of a shocker when we took it apart again .my car is by no means rusty underneath and i did not expect this mess . steel brake pipes on a car which is designed for off roading is a disgrace . mine is all copper now . hope this is of help to someone
Post #417681 13th Dec 2016 2:45am
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I can't help specifically with your problem I'm afraid, other than to say ours has a King system fitted and it very well behaved.
Many LPG systems have a setting to delay the switch over until 20secs or so of start to prevent it trying to switch when the revs flare at start up. This may have been set too low or off so it's trying to get on to gas before it's running properly.
Post #417694 13th Dec 2016 9:15am
There will also be an overlap setting where it runs on LPG and petrol for a 1/2 second or so on changeover, if this is set low then it can cause your symptoms... Thumbs Up Pete
Post #417703 13th Dec 2016 11:10am
rik
hi thanks for that however changeover occurs when revs are over 1500 assuming engine temp is correct . mine is set to changeover on acceleration but can be changed to deceleration is your eml light on ?
Post #417709 13th Dec 2016 1:40pm
Sorry, misread that, so it dies when starting on petrol...???
Mine is set to start on LPG if it is warm enough so only uses petrol to start when cold...
No EML light on mine, runs superb on LPG, check your fuel trims on LPG, they should be less than 10% out... Pete
Post #417712 13th Dec 2016 1:46pm
rik
yea when starting on petrol only . i might try changing vaporiser as i suspect a leak somewhere if i can locate one . she runs perfect on lpg and gas only starting when hot is the problem when i first bought car the problem was not there for around 6 months then wala eml light on and tickover when hot prob i would love to cure it bas car is running great otherwise
Post #417761 13th Dec 2016 6:51pm
Could be leaking injectors, you switch off and they dribble petrol into the engine so when you start it, it's flooded and cuts out, then clears straight away and it's OK, leave it until it's cold and the petrol has evaporated and everything is normal again... Pete
Post #417763 13th Dec 2016 7:09pm
rik
ok but why why it not do this if running on petrol only ?
Post #417851 14th Dec 2016 12:36pm
Ah, OK, so you run on gas, switch off and it won't start, run on petrol and it does...
That and the EML lead me to think it needs someone with experience to set it up properly, if the tech says the old chestnut "they all have the light on" then find another one who knows how to do it properly.
It's very easy to make a car run on LPG and "appear" to work fine when in fact it is running very rich..... Pete
Post #417873 14th Dec 2016 2:13pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
how did you get on with this ??
engine light should not be on unless the system is faulty, my guess for this problem would be the LPG system is running to rich, the petrol ecu is retarding the fuel flow to over compensate the extra LPG I would hazard a guess if you were to reset the light and run the car purely on petrol for 100 miles + all will be well
A very common problem when people who don't know what there doing play with LPG
Post #429179 25th Feb 2017 10:21pm
