![]() | Home > LPG > lpg no tickover when starting |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
I can't help specifically with your problem I'm afraid, other than to say ours has a King system fitted and it very well behaved.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8499 ![]() ![]() ![]() |
There will also be an overlap setting where it runs on LPG and petrol for a 1/2 second or so on changeover, if this is set low then it can cause your symptoms... |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
hi thanks for that however changeover occurs when revs are over 1500 assuming engine temp is correct . mine is set to changeover on acceleration but can be changed to deceleration is your eml light on ? |
Sorry, misread that, so it dies when starting on petrol...???
yea when starting on petrol only . i might try changing vaporiser as i suspect a leak somewhere if i can locate one . she runs perfect on lpg and gas only starting when hot is the problem when i first bought car the problem was not there for around 6 months then wala eml light on and tickover when hot prob i would love to cure it bas car is running great otherwise |
Could be leaking injectors, you switch off and they dribble petrol into the engine so when you start it, it's flooded and cuts out, then clears straight away and it's OK, leave it until it's cold and the petrol has evaporated and everything is normal again... Pete
ok but why why it not do this if running on petrol only ? |
Ah, OK, so you run on gas, switch off and it won't start, run on petrol and it does...
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
how did you get on with this ??
