Key Stuck in the Ignition | |
I am new to the forum , so Hi to all members.
Has anyone any advice on removing a stuck ignition key?
I have had my nine year old Range Rover from new and its done just under 50,000 miles , so not a lot of use .
Just over two years ago the key stuck in the ignition and a new barrel was fitted , the problem recurred and a gearbox sensor cable was replaced .Apparently there is a safety lock which stops the key from being removed while the vehicle is in motion ! Well thats what I was told at the time .
Now the key has stuck again , I am told that the barrel needs replacing and because the previous replacement barrel is over two years old it is not under warranty . Can you believe that ? I am querying this with Land Rover but no luck to date .
I have seen a USA forum which refers to parking brake sensor problems and removing a solenoid from the steering wheel console to fix the issue . I am not a mechanic and therefore loathe to delve ! But equally I hate the thought of giving another thousand pounds to Land Rover .
Any advice would be greatly appreciated.
Thanks Howard
