Home > Maintenance & Mods (L322) > Key Stuck in the Ignition
HJB
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I am new to the forum , so Hi to all members.
Has anyone any advice on removing a stuck ignition key?
I have had my nine year old Range Rover from new and its done just under 50,000 miles , so not a lot of use .
Just over two years ago the key stuck in the ignition and a new barrel was fitted , the problem recurred and a gearbox sensor cable was replaced .Apparently there is a safety lock which stops the key from being removed while the vehicle is in motion ! Well thats what I was told at the time .
Now the key has stuck again , I am told that the barrel needs replacing and because the previous replacement barrel is over two years old it is not under warranty . Can you believe that ? I am querying this with Land Rover but no luck to date .
I have seen a USA forum which refers to parking brake sensor problems and removing a solenoid from the steering wheel console to fix the issue . I am not a mechanic and therefore loathe to delve ! But equally I hate the thought of giving another thousand pounds to Land Rover .
Any advice would be greatly appreciated.
Thanks Howard
Post #417588 12th Dec 2016 12:57pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
This seems to be a common solution.
http://www.fullfatrr.com/wiki/Key_stuck_in_ignition
Post #417589 12th Dec 2016 1:15pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Hamlet is exactly correct and his link worked for me when it happened.
My FF gets left unused for quite long periods and on return from 4 months away the key wouldn't come out. Liberal amounts of WD40 and 3 in 1 oil on the points in the picture and all was sorted. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #417598 12th Dec 2016 4:07pm
HJB
Many Thanks Lads . Problem sorted . It is still sticking intermittently but now I have a "fix" I can drive it without concern.
I am amazed that Land Rover didn't point out that in an emergency one can "override" the system . Perhaps it is buried in the manual somewhere !
Meantime my thanks once again.
Howard
Post #417614 12th Dec 2016 5:05pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Happened to me this afternoon. Clicked on the link and all sorted. God bless the Forum🙂. Is this supposed to be looked at in one of the service intervals? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #571730 3rd Nov 2020 3:34pm
