Home > Technical (L322) > PCV System replacement Quote + Gearbox and Diff
pmthompson
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Hi all,
I just had a quote for the PCV system gearbox and Dif oil replaced. Can you check my quote. They don't mention oil separator. Anything else missing? See Grab.
https://s15.postimg.org/vfuz0gyln/quote.jpg
Post #417134 8th Dec 2016 1:29pm
Thumbs Up ... - .- -.
Post #417135 8th Dec 2016 1:31pm
DoubleRL322
United States 2003 Range Rover HSE 4.4 V8 Zambezi Silver
There are 4 hoses total which you should replace, I only see three on the estimate.
In addition to the two breather hoses, make sure they change 6C342A and 6C342B in the attached diagram as well as the cyclonic oil separator (unless they are just cleaning yours, however when I removed mine it was pretty gunked up so I just went with a new one).
Post #417142 8th Dec 2016 2:41pm
DoubleRL322
Oh, also I do not see the gasket for the "breather", i.e. PCV valve. That gasket should be replaced as well.
Post #417143 8th Dec 2016 2:42pm
