![]() | Home > Technical (L322) > PCV System *preventative work* |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Doing mine and associated hoses this weekend..take your engine cover off and look at the back where its in situ...my pipes are soft and gummy and a definite problem in the making...don't reckon mine has ever been changed...if it goes it can cause you to lose your engine through oil loss, best case scenario is leaking pipes leaving your engine in a oily mess with ...mines is the latter and certainly worth spending £100 on as a safeguard |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Oh yes, that and the oil separator and it's 3 pipes. Also look to do the thermostat hack there's a good thread on here all about it, Haylands (Pete) did a very good write up. It lowers the temps in the engine and is probably the best mod you can do to extend the life of your engine / cooling system.
Also have a read up on Petes (haylands) post on upgrading the thermostat...makes a lot of sense.. My next job after the pcv system... |
Haha..beat me to the thermostat mention |
pmthompson Member Since: 04 Dec 2016 Location: Chelmsford Posts: 7 ![]() ![]() ![]() |
Nice, thanks. I will. Any other little tips. I was thinking Gearbox/Diff fluid swap for starters... |
Not intentional mate |
Always a good idea to do fluids and filters but our rangies need specific fluids, if you do it yourself then you know what goes in, but if you put it into a workshop then make sure they know what fluids and the methods of putting them in.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Cam cover gaskets is another favourite, mine was dumping oil in a couple of spark plug holes and also oil over the smoking hot exhaust.
