Home > Technical (L322) > PCV System *preventative work*
pmthompson
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Hi all
Just purchased, 2002 L322 Vogue 4.4 V8 Petrol with 140K on the clock. Very good condition. Gearbox overhauled 2012. Had full service 1st Nov
New Fuel Pump, water pump, condenser rad, Oxygen sensor, crank sensor.
Its sweet now and i want to keep it that way. I hear doing the PCV system is a smart mans move.
Fill me in. Is it worth it?
Post #417017 7th Dec 2016 5:26pm
alistairh
Doing mine and associated hoses this weekend..take your engine cover off and look at the back where its in situ...my pipes are soft and gummy and a definite problem in the making...don't reckon mine has ever been changed...if it goes it can cause you to lose your engine through oil loss, best case scenario is leaking pipes leaving your engine in a oily mess with ...mines is the latter and certainly worth spending �100 on as a safeguard Thumbs Up
Post #417019 7th Dec 2016 5:35pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Oh yes, that and the oil separator and it's 3 pipes. Also look to do the thermostat hack there's a good thread on here all about it, Haylands (Pete) did a very good write up. It lowers the temps in the engine and is probably the best mod you can do to extend the life of your engine / cooling system.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #417020 7th Dec 2016 5:35pm
alistairh
Also have a read up on Petes (haylands) post on upgrading the thermostat...makes a lot of sense.. My next job after the pcv system...
Post #417021 7th Dec 2016 5:37pm
alistairh
Haha..beat me to the thermostat mention Laughing
Post #417022 7th Dec 2016 5:37pm
pmthompson
Nice, thanks. I will. Any other little tips. I was thinking Gearbox/Diff fluid swap for starters...
Post #417023 7th Dec 2016 5:39pm
UK Marine
Not intentional mate Laughing . It's a good mod though, I did mine and when I started it up for the first time it just sounded different, more relaxed if that sounds right.
Anyway it doesn't effect the interior heating at all, still nice and toasty Thumbs Up
Oh and very fast delivery too....... ______________________________
Simon
Post #417024 7th Dec 2016 5:42pm
UK Marine
Always a good idea to do fluids and filters but our rangies need specific fluids, if you do it yourself then you know what goes in, but if you put it into a workshop then make sure they know what fluids and the methods of putting them in.
Simon
Post #417025 7th Dec 2016 5:49pm
holidaychicken
Cam cover gaskets is another favourite, mine was dumping oil in a couple of spark plug holes and also oil over the smoking hot exhaust.
I have the thermostat mod to do and I also have a brand new standard 88 deg stat that is a straight swap which I might chuck in for ease
Post #417082 8th Dec 2016 12:33am
