Home > Technical (L322) > Flashing rear lights
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Now that we have darker nights I have noticed that the rear lights flash when I turn off the ignition. The light switch is in the off position and the car is dark, but when I turn the key and remove it I can see a reflection in my neighbours window of my rear red lights flash just the once. Dont know which (brake or side) but why do they do it? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #416949 6th Dec 2016 10:23pm
Are they LED, as the cold monitoring which fires a low voltage at the lamp to see if it is working will illuminate an LED but not an incandescent bulb...
You can turn off a lot of cold bulb monitoring in the CCF with an IID or similar but not the sidelights...
If not, I haven't got a clue...!! Pete
Post #416951 6th Dec 2016 10:28pm
Mr Tee
My old one did the same
Post #417002 7th Dec 2016 2:01pm
Spelunker
Definitely not led and they dont flash - they come on.....then go off. Almost as long as the indicators when you lock the car but it only happens when I turn the ignition off and the lights are not on...... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #417182 8th Dec 2016 7:13pm
