Home > Technical (L322) > Groan when turning left! |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Any ideas? There's been knocks and bangs l over the place for a while now, finally getting to them since changing my front airbags and struts
6th Dec 2016 12:35pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Had this recently. It got worse and worse until even the missus noticed. Eventually took it to my Indy who diagnosed drop links and control arm type things. Did the lot plus nearside suspension turret bearing. Pleasure to drive again after fettling. Previous cars:
6th Dec 2016 2:58pm |
Hm that sounds like it might be good.
6th Dec 2016 5:17pm |
Time for an update!
6th Dec 2016 8:25pm |
Is there any way to find out? Or just hear it on the grape vine?!!
6th Dec 2016 8:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8625 |
I think it just depends on who was the nominated supplier at the time the car was made. I ordered a set of OEM arms from ducky Dan and a set of ball joints which Were gen LR. Then ball joints were lemforder in a LR box, the arms were Delphi, I just replaced he drop links on mine and they were lemforder in a LR packet too. I wouldn't worry about lemforder parts, they are part of ZF! There is nothing that can't be fixed with a hammer😜😜
6th Dec 2016 8:51pm |
That makes sense!
6th Dec 2016 8:58pm |
Washers are RYF000021
6th Dec 2016 9:03pm |
Cheers, have got the part number.
6th Dec 2016 9:50pm |
Before I start to do the lower arm, the torque settings are:
Now i'm guessing this is with the car completely on the ground with the wheels on, do I tighten to 165nm then turn the nut/bolt another 90 degrees? Or do I tighten to 165nm with the car jacked up, then another 90 degrees when lowered? I can tell already it's going to be a to get the torque wrench in there!! |
7th Dec 2016 12:56pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Since it only groans on turning left, I would simply follow the political zeitgeist and only turn right |
7th Dec 2016 3:18pm |
Thinking of which, on my commute to work I only have to turn right, except when I get to the end of the business park I have to take a left, its the journey home that the problems occur Will tackle it in about an hour, can't wait. Knocking noises really really annoy me and hopefully it will make the ride a bit better, the car has felt all over the place in the last few days since I've noticed it getting worse. Probably owed to a pot hole that West Berkshire council don't seem to give a about! Going to strip down the brake calipers while i'm at it as well, hopefully get rid of the 'bonk' as I hit the brakes lightly. Did some research earlier and it's possible that the retainers for the pads either aren't fitted or haven't been put in properly. If that fails, at least the greasing will stop the squeaky brakes. Doesn't look very good in Pangbourne, for those who don't know this area its a little quiet village full of zebra crossings and old people. I happen to work there! |
7th Dec 2016 4:06pm |
Tighten on the ground, so the bush is seated in the right position. It's a PITA to get the torque wrench in there, don't ask me how I know, suffice to say I had paid for the job to be done wrong..... There is nothing that can't be fixed with a hammer😜😜
7th Dec 2016 6:10pm |
Just for those who ever find this thread in a search because their car groans when they turn;
8th Dec 2016 3:06pm |
