Home > Maintenance & Mods (L322) > L322 4.2 s/c gearbox problems please help!
Mclarke155
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
Hi guys,
Got myself a 4.2s/c L322 about 18months ago! Love the car and the way it drives however has always had some slight problems with the gearbox!
Firstly when I test drive the car, it came up with a fault saying transmission change not available selected gears only!
The car was then sent to a specialist by the garage I was buying it off. It supposedly had a full gearbox oil change and filter.
I wasn't convinced this was done as a couple of months after I found the plastic dump was cracked and filled with putty!!
Long story short, I fitted a replacement dump pan and new filter, oil ect.
Gearbox has always felt slightly harsh when changing. Always had a noticeable thump when coming to a stop from a reasonable speed. Also when accelerating under load when changing gears the revs shoot up and then back down into the next gear!
More recently the gearbox has become a lot more 'thumpy' and is saying change not available and it locks into gear! If I then turn the car off and back on it seems to work again.
Took it to my local garage who yet again changed the oil for proper zf fluid, (was previously changed with dextron equivalent)
After fault scanning the box, it showed 1-2 shift change and 2-3 shift fault. Cleared the code and drove it, scanned again saying 3-4 now!
We then reset the adaptation on the box. Thinking it may cure it however made things ten times worse resulting in a car that is barely driveable! Read up online and found an adaptation re learning procedure however I could not get it to re learn (unsure whether I was doing it right or not tbh!)
Was told it may be the torque converter however after taking it to a gearbox specialist he has recommended a full rebuild, including new torque converter. He said the box had end float and the phosphor bronze parts were most likely worn. Quoted me �1800/�1900 with a 12month warenty.
So my main question is does this sound reasonable, and had anyone had any similar issues/fixes? I have tried searching the forum but couldn't find any links to my specific problem.
Also if anyone knows the Coreect re learn procedure for this gearbox I am more than willing to try again if it means saving �1900! Razz
It is the 6 speed zf6hp26 I think!
Thank you! Smile
Post #416856 6th Dec 2016 12:49pm
RRPhil
By far the most common issue with the 6HP26 is faulty solenoids.
If the rear stator bush had worn you wouldn�t be able to get into 4th, 5th or 6th gears as the E-clutch would be leaking/slipping.
If it were me, I�d take the mechatronic unit out and send it off to Pete Stirrup for testing (www.valvebodyuk.co.uk) to confirm that you have problems with the solenoids. If so, he can replace them.
Too late, I know, but you should never reset the long-term adaptions unless you�re replacing the transmission or mechatronic unit - certainly not with just a fluid change. The 6HP26 will quite happily destroy its clutches as the controller struggles to find the new pressure settings to achieve the correct shift times. A change in the fluid friction modifier pack (i.e. by using the wrong fluid) and faulty solenoids makes the situation still worse.
Phil
Post #416885 6th Dec 2016 4:27pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I did as above earlier in the year. I sent my valve body to a firm in Luton (can't recall the name at the moment), they tested it and found some faults which they repaired. I reassembled with new seals, sump and oil and then reflashed the software using my IID tool. Almost 12 months later and the problem I had (similar sounding to yours) hasn't reappeared.
Post #416897 6th Dec 2016 5:29pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
not the same car but I had my TD6 box reconned with a new torque converter 4 years ago and paid just shy of �2000 at an auto box specialist with 2 year/24,000 mile warranty (whichever came first)
Post #416903 6th Dec 2016 5:56pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I've had exactly the same issue on a similar car and gearbox, luckily I became one of Phil's guinea pigs. All of the problems were down to one solenoid. Yes, just one of them!
Knowing what I know now I would not be reconditioning gearboxes and torque converters, you are almost sure to spend an enormous amount of money changing all the parts that do not need changing.
If you want my advice, follow RRPhil's guidance. What he doesn't know about automatic transitions is not worth knowing! Bow down
Good luck! Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #416916 6th Dec 2016 7:48pm
Mclarke155
Thanks for the response guys! RRphil, if I was to remove the mechatronic unit, send it off for testing is there a cheap way of re flashing the gearbox software now I've reset the adaptations like a fool? Razz cheers
Post #416967 7th Dec 2016 6:20am
kezbo1981
If you have an IID tool you can do it with that, for a small extra fee.
Post #417159 8th Dec 2016 5:40pm
jonbaobao
2007 Range Rover Supercharged 4.2 SC V8 Java Black
Thanks to the contributors. This has solved my problems by IID TCM flush and replaced solenoid valves.
Post #427824 15th Feb 2017 6:10am
rar110
Lots cheaper than a new gearbox. ______________________________
Post #427848 15th Feb 2017 10:36am
kezbo1981
Great news!
Post #427951 15th Feb 2017 10:39pm
jonbaobao
This fixed my problem couple of years ago. Now it is coming back intermittently. Reset fault and will go back to normal for a month or two. Now it also reads bank 1 rich sometimes. Can the bank 1 rich code and the transmission fault related?
Post #511448 9th Apr 2019 2:51pm
Bulldoza007
United Kingdom 2007 Range Rover SE 4.2 SC V8 Santorini Black
I have a problem with my gearbox it seams that 4th 5th and 6th is slipping with a thump and sometimes it won't go into higher gears at all please help
Post #715375 1st Apr 2025 10:19pm
RRPhil
Just do a search on here for rear stator bush wear.
Phil
Post #715378 1st Apr 2025 11:10pm
Bulldoza007
I've tried and can't seam to get any information. Do I need a ful gearbox rebuild for this problem ?
And I see your local to me.. Could you recommend someone in Lancashire who could fix this for me as I don't want to just throw mo ey blindly at this.
Post #715380 1st Apr 2025 11:54pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
https://www.bing.com/search?q=rear+stator+...lfatrr.com 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #715383 2nd Apr 2025 8:30am
