![]() | Home > Maintenance & Mods (L322) > L322 4.2 s/c gearbox problems please help! |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
By far the most common issue with the 6HP26 is faulty solenoids.
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
I did as above earlier in the year. I sent my valve body to a firm in Luton (can't recall the name at the moment), they tested it and found some faults which they repaired. I reassembled with new seals, sump and oil and then reflashed the software using my IID tool. Almost 12 months later and the problem I had (similar sounding to yours) hasn't reappeared. |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
not the same car but I had my TD6 box reconned with a new torque converter 4 years ago and paid just shy of £2000 at an auto box specialist with 2 year/24,000 mile warranty (whichever came first) |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I've had exactly the same issue on a similar car and gearbox, luckily I became one of Phil's guinea pigs. All of the problems were down to one solenoid. Yes, just one of them!
Mclarke155 Member Since: 06 Dec 2016 Location: Birmingham Posts: 3 ![]() ![]() ![]() |
Thanks for the response guys! RRphil, if I was to remove the mechatronic unit, send it off for testing is there a cheap way of re flashing the gearbox software now I've reset the adaptations like a fool? |
If you have an IID tool you can do it with that, for a small extra fee. |
jonbaobao Member Since: 12 Jun 2014 Location: Taiwan Posts: 6 ![]() ![]() |
Thanks to the contributors. This has solved my problems by IID TCM flush and replaced solenoid valves. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Great news! |
This fixed my problem couple of years ago. Now it is coming back intermittently. Reset fault and will go back to normal for a month or two. Now it also reads bank 1 rich sometimes. Can the bank 1 rich code and the transmission fault related? |
Bulldoza007 Member Since: 01 Apr 2025 Location: Preston Posts: 2 ![]() ![]() ![]() |
I have a problem with my gearbox it seams that 4th 5th and 6th is slipping with a thump and sometimes it won't go into higher gears at all please help |
Just do a search on here for rear stator bush wear.
I've tried and can't seam to get any information. Do I need a ful gearbox rebuild for this problem ?
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
https://www.bing.com/search?q=rear+stator+...lfatrr.com 2016 Skoda Octavia VRS Estate
