Home > Technical (L322) > Fitting deployable steps
Page 2 of 3 <123>
Just got all my bits for my install, i think the instructions have to read carefully as there is instructions for both the 2010 -> and ->2010 models in the same sheath of papers. i dont think you have to use the big blue plug in the pre 2010 wiring looking at it.
Jammer - I have those 2 white plugs on my harness too. Im not sure they should be on a pre 2010 harness...... check your part no. for the harness. if its 00080 then you had the latter 2010 -> harness, and this could be why your button dont work. your wiring kit should be no vplmv0022 Thumbs Up
the positive connection goes piggyback into a plug on the top of the fuse box. as far as i can tell
Had a run through of the whole process in the book and I'm missing a part!!!!! Whistle Censored Big Cry only a small bit and I'm not going to fit them for a while so hopefully the dealer will be able to locate it. its the small clip on plug which goes in the roof console, worst comes to the worst i can splice the wires with a crimp, not ideal though.
Just noticed that the harness that has been supplied vplmv0080 comes with autobiog black instructions. According to parts info the wiring harness i have is the latest part no and superceedes from VPLMv0023, however there are the 2 extra white plugs on this newer harness which dont appear on the older one. can't think what they are for, but the black instructions show where they connect in, however this isn't shown on the earlier harness instructions as the plugs aren't there. I wonder what they do incase it is autobiog black specific....... can't think the harness in the car would be different though so hoping that the connectors they plug into are in the car Big Cry . There is nothing that can't be fixed with a hammer😜😜
Post #414846 22nd Nov 2016 8:14pm
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Are you sure it's not already connected to the plug? Mine was, I had to remove it then put the wire in and then re connect
My ff is a 10my so should be right, also there's nothing in the manual stating how to connect ?? 2018 Suzuki Jimny 2003 written off
2016 Range Rover TDV8 MY10 current
2013 Range Rover TD6 2005
2012 Defender TDCI 2007
2010 Toyota Hilux 2003
2009 Audi TT 1.8T 225
2007 Suzuki SJ 413 with 1600 fitted
2006 Yamaha R6 2000 still have this
2006 Audi A3 1.8T 1999
2006 Defender TD5 1998
2005 Audi A3 1.6 1998
2004 Suzuki vitara 1994
2002 Proton 1500tripple valve 1991
Post #414864 22nd Nov 2016 10:16pm
ah yes, so it is, a 2010. plug deffo not in the harness though.
I have those 2 connectors on the loom too and looking in the autobiog book which came with the harness they do go somewhere. there is 2 connectors in and around the glove box area which loop through. its not detailed in the A4 instructions though. p4 step 10 in the harness manual. Thumbs Up
however, in that instructions the 2 larger plugs aren't used, the ones which loop through the unit under the dash. they are taped out of the way and the 2 white ones are used instead. I think that generally speaking if the white ones are present on the car then we use them, if not then use the 2 larger plugs. There is nothing that can't be fixed with a hammer😜😜
Post #414868 22nd Nov 2016 10:28pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
I called a dealer today and they want £700 to fit saying it's a days work.
I've heard that someone on here fitted them in 4 hours. Are the dealers taking the ****? 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #416275 2nd Dec 2016 11:16am
duckworthparts
Site Sponsor
official book time is 2.5 more of a realistic time is 4 hours You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #416276 2nd Dec 2016 11:27am
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi, agree with Dan on this, took me a little longer than 4 hours, but I didn't have the luxury of a big workshop. If you have some basic tools, google any bits your not sure on, ie removing some trim, you can save £250 if you can get them fitted for £700. Others have paid £900, so we worth doing yourself. SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Triumph Bonneville 1970
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
4.2 E type Jag replica (challenger)
Escort RS2000 (many)
Escort RS 1600 Turbo
Post #416281 2nd Dec 2016 12:09pm
87RJD
Just re read your post, was that £700 to fit, plus purchase? if so that makes it even more worthwhile DIY fitting. SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
Post #416282 2nd Dec 2016 12:11pm
Andy B
Took LR dealer Guy Salmon in Aylesford a day and half to fit mine! They ended up supplying an Ewok as a loan car as they originally quoted 4 hours labour (Ewok = nah). Well done to those brave souls that have fitted them themselves, hats off to you guys! Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #416335 2nd Dec 2016 5:35pm
andygts
Did they say why it took so long? They've got to have had the tea butch fitting them to take that long Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #416344 2nd Dec 2016 5:58pm
supershuttle
I agree with AndyB - respect to them that fitted themselves. I eventually got a good deal on supply and fit (took almost a day) so didn't need to have a go myself - I'd still be struggling and getting frustrated.
It was a bit of a drag to get over to Leeds (Green Oval) but well worth it although the taxis to and from Leeds centre with SWMBO and the Christmas shopping and the pub lunch - oh and the pub in the afternoon all added to the cost, but I can't stop looking at them and operating them, great things, very pleased.
Oh and I pointed out to SWMBO that they might be her Christmas present as I can get in and out without any trouble - but I suspect it wont be Rolling with laughter Geoff
Post #416349 2nd Dec 2016 6:15pm
Andy B
I don't know, but I reckon they broke something when fitting the steps and electrics and had to order a replacement part overnight Whistle I saw them driving the car into the workshop at 08:00am on the first day, all very suspect. Still, they did a good job in the end for the offer price and at least I have a 2 year warranty Thumbs Up
Agree with Geoff though, a top feature for a fatty Very Happy SDV8 AB MY 2019
Post #416355 2nd Dec 2016 6:45pm
All then it's are now present!!!! I picked up the missing connector, it was in the end of the loom in the second one they sent.
Just waiting for a nice day now!! There is nothing that can't be fixed with a hammer😜😜
Post #416370 2nd Dec 2016 8:32pm
Rich86
Here are mine - all fitted and working perfectly. 2009 Vogue TDV8 Nara Bronze
Post #418938 21st Dec 2016 6:26am
supershuttle
@ Stan, I don't have a LR warranty on the vehicle so that wasn't such a concern but I just didn't fancy the time doing it or the actual doing it as I knew I would struggle despite others pointing out how easy it is. But even at the price 'wot I paid they're great things to have and if I can put this in the same para. as LR - good value too Rolling with laughter Geoff
Post #418942 21st Dec 2016 7:06am
i should imagine the parts are guaranteed for two years Geoff.. ... - .- -.
Post #418953 21st Dec 2016 8:23am
Page 2 of 3 <123>
