Home > Technical (L322) > Idle problem
Skip720
England 2002 Range Rover HSE 4.4 V8 Oslo Blue
Idle problem
I have a L322 with a m62 engine, when the car is warm the idle seems to drop to about 400 Rpm and nearly cuts out. Any ideas??
Post #415807 29th Nov 2016 1:07pm
holidaychicken
Could be air leak in the vacuum system somewhere, there are a few small pipes that are vulnerable
Have you got any diagnostics?
MAF maybe ?
Post #415889 29th Nov 2016 8:29pm
Skip720
I have the I car soft thing . How would I use it to find out?
Post #415894 29th Nov 2016 8:56pm
holidaychicken
Never used the icarsoft but would expect you connect it to your OBDII port and scan engine ECU
Anyone used icarsoft?
Post #415910 29th Nov 2016 10:09pm
i'm sure someone has, do a search ... ... - .- -.
Post #415911 29th Nov 2016 10:13pm
holidaychicken
http://www.scantool-direct.co.uk/user/iCar...Manual.pdf
Post #415912 29th Nov 2016 10:15pm
alistairh
You can check maf readings in it no probs..select engine, select data stream and mass air flow readings are there...you can also select obdii diagnose and select it from there in either numerical readings or via graphs!
Post #415914 29th Nov 2016 10:41pm
Dolphinboy
Sounds like the MAF. Mine was dirty so I replaced it with a new one and she purrs nicely at 750 rpm now.
Post #415939 30th Nov 2016 9:22am
Skip720
Thanks guys. I will have a look tonight.
Thanks again
Post #416001 30th Nov 2016 2:00pm
